02-14-2013, 06:17 PM | #1 |
Door hinge bolts
For those of us with Task Force trucks that have taken the doors off and removed the hinges and the bolts were all rusted up, when you turned the bolt and it turned the caged nut inside the door jamb and bent up or broke out the cage to keep the nut in place and from turning what did you do to repair or replace the cage and the nut ?
Gene |
02-14-2013, 06:30 PM | #2 |
Re: Door hinge bolts
i just made a new cage nut. square metal with drill and tapped hole.
the few cage repairs i made were just 10 ga metal bent in a vise and welded on lmc truck sell the cages and nuts i believe
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-18-2013, 09:57 PM | #3 |
Hello 57 half ton. Saw your question about your hinges. I had the same problem and this is what I came up with. Hope it helps.
02-18-2013, 10:03 PM | #4 |
Nice fix. I guess I was lucky (not). The whole lower hinge mounting area in my truck was rusted out. I welded in the new assembly. The uppers on mine were intact.
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
