Old 02-14-2013, 10:00 PM   #1
savatreatabvr
savatreatabvr's Avatar
Missing Factory Emissions Equipment?
I'm getting ready to take my 1973 C20 454 through emissions here in Arizona but I don't have any smog equipment, no EGR, no CATs no PUMP, nothing. The truck originally came with a 350 so I'm wondering if smog equipment was even required on a 1973 C20. I've looked online for a emission parts list for my truck but haven't found anything so any help on this matter is much appreciated!
savatreatabvr is offline   Reply With Quote
Old 02-14-2013, 11:07 PM   #2
KrazyRay
KrazyRay's Avatar
Re: Missing Factory Emissions Equipment?
The 73 with a 454 usually came with no EGR or it had a factory EGR blockoff plate. I don't think it would have a smog pump or tubes on the exhaust manifolds. I may be wrong, but the only thing you need is a PCV. Good luck!
KrazyRay is offline   Reply With Quote
Old 02-14-2013, 11:53 PM   #3
MusicMan70
MusicMan70's Avatar
Here's what my 73 stock 454 looks like; no AIR pump or EGR. Smog pump in California only; I think. This truck was originally from Washington State
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 02-15-2013, 05:03 AM   #4
savatreatabvr
Thanks for the picks MusicMan70! I believe 1975 and up C20s require Cats so I think I'm good there. Now I wonder if my aftermarket air cleaner will pass or do I need the factory air cleaner?
Old 02-15-2013, 12:20 PM   #5
rfmaster
rfmaster's Avatar
'75 model year was the last year of no CAT's for HD trucks (engine emission family 113) in CA. You'll need stock air cleaner assembly with heat air for the thermatic valve and air purge tube between air-cleaner and valve cover. AIR injection is required for 75 SBC and BBC trucks in CA. No EGR and that's about it.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-15-2013, 02:10 PM   #6
savatreatabvr
I have a nipple on the bottom of my chrome aftermarket air cleaner, I'm assuming if I run a hose from the valve cover to the nipple I'd be fine, it's doing the same thing as the factory air cleaner, right?
Old 02-15-2013, 10:35 AM   #7
Zane M
It depends on how stringent your testing facility is. Technically the valve cover breather would route into the air cleaner so those fumes would be consumed through the air supply to the carb for combustion purposes.
I have trucks set up like yours, and don't have any issues here in Utah.
Zane M is offline   Reply With Quote
Old 02-15-2013, 11:23 AM   #8
KrazyRay
KrazyRay's Avatar
You will probably need the heat stove on the exhaust with the riser tube going to a stock air cleaner and the PCV going from the valve cover to the spacer above the carb. I've seen 3/4 ton trucks in CA without smog pumps up to 1978, however, I have a stock 1973 1/2 ton with all of the smog garbage on it. The GVW has a lot to do with smog equipment.
Old 02-15-2013, 06:17 PM   #9
86swb
Born a Chevy Man
86swb's Avatar
Man, I am glad we do not have those emission test here in Kentucky. I do not have any emission equiptment on eather my 86 or 84.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 02-15-2013, 07:53 PM   #10
Oilbrnr
Oilbrnr's Avatar
In Maricopa and Pima counties for that year and GVCW all you need is the PCV.
Believe me, I have to do the annual ADEQ dance with my '77 K5 and '80 K20, both of which just escaped many requirements by GM tweaking the trucks ratings in those model years (esp. the K20).
Neither have EGR, cats, evap or smog pumps. Just make sure that PCV system is hooked up and functioning. The air cleaner is fine, but that breather off the valve cover = fail.
Good luck! It is a PITA having to go back if you fail the sniff test.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 02-15-2013, 08:49 PM   #11
Hevy
Hevy's Avatar
Yeah, take the breather off and run the hose from air cleaner to valve cover and you should be good to go, as far as equipment...
Hevy is offline   Reply With Quote
Old 02-15-2013, 11:42 PM   #12
savatreatabvr
Yes, emissions here in the Valley of the Sun is tough but since we live in a "Valley" where it's rarely windy the smog doesn't get blown away it just hangs over us! I dropped a valve in my '78 Z28 one night and got pulled over blocks from my house for excessive smoke and given a equipment repair ticket! But the biggest contributor to the pollution problem here is the city buses! Phx needed to blow some money so they built an electric light rail system to help with the smog but the buses still run and still smoke!
Old 02-15-2013, 09:18 PM   #13
Oilbrnr
Oilbrnr's Avatar
Be prepared for the inspectors to scratch their heads for a bit and possibly refer to the big 'bible' that they have there. My K20 usually always involves the station manager to do the once over as well.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
