disc brakes with single master
im doing a disc conversion on my 65 my question is can i run the single master for alittle while while i save for the rest of the job thanks
Re: disc brakes with single master
Pretty sure you need the dual master to run disc. Also need a pop valve to adjust pressure between the front and rear brakes
Posted via Mobile Device |
I feel that a dual pot MC is the single most safety item you can do to our trucks. They have a disc/drum MC that isn't a power assist if you want it.
#4 | |
Just my 2 cents.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
I agree with above. Switch to dual master. I used this thread to do mine before I switched to power. http://67-72chevytrucks.com/vboard/s...d.php?t=332148
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
thanks guys looks like a dual master for me then
You cannot-the OE drum MC has a check valve which will keep pressure on the discs.
![]() Join Date: Sep 2009
the pressure for front and back brakes are differant for disc and drum. if you run it like that you will be only be running one set of brakes. plus the masters are really cheap.
