Old 02-15-2013, 07:23 PM   #1
jeremys14
fuel issue
in my 64 i have the behind seat tank still. po put in 72 dash, meaning a 90 ohm gauge. as you know my tank sending unit is 30ohm. does anyone make a 90ohm in the cab mounted tank sending unit? im tired of topping off every time i drive to make sure i dont run out if gas
jeremys14 is offline   Reply With Quote
Old 02-15-2013, 07:43 PM   #2
WhippinSaw
WhippinSaw's Avatar
Re: fuel issue
This might work : GM Fuel sending unit conversion 30 ohm
http://www.hotrodders.com/forum/gm-f...hm-106069.html
WhippinSaw is offline   Reply With Quote
Old 02-15-2013, 11:43 PM   #3
jeremys14
Re: fuel issue
thanks but thats the opposite of what im looking for. ive found several things on if you have a 90 sending unit making it work on a 30 gauge. i have the exact opposite problem. i need a 90 sending unit that will fit behind the seat of my 64, so it will match my 90 fuel gauge from a 72
Old 02-16-2013, 12:23 PM   #4
luvbowties
luvbowties's Avatar
Thumbs up Re: fuel issue
I've fiddled with fuel gauges a pretty fair amount. With your situation, the only solution I see is grafting a later model sending unit onto your sending unit--all mechanical, instead of electrical from here out.
Hth,
sam
luvbowties is offline   Reply With Quote
Old 02-16-2013, 02:59 PM   #5
jeremys14
Re: fuel issue
im beginning to think my easiest option is to just get an autometer 30ohm fuel gauge. just really wanted to keep the old guages
Old 02-16-2013, 03:12 PM   #6
luvbowties
luvbowties's Avatar
Smile Re: fuel issue
Jeremy, mating 2 sending units may be simpler than you first think. You essentially cut 2 pipes and join 2 pipes using flex fuel hose & 2 clamps. (I'd use fuel-injection hose.) You'll prolly need 2 inches of it!
And, if you're lucky, maybe the '67 send unit is a simple bolt-in. Look at both at a parts house & compare?
sam
Old 02-16-2013, 03:51 PM   #7
WhippinSaw
WhippinSaw's Avatar
Re: fuel issue
Maybe this can work, Adjustable 6-24" Fuel Tank Sender 0-90 Ohm
http://www.gearheadworld.com/store/C...-P7991C87.aspx
http://67-72chevytrucks.com/vboard/s...d.php?t=288717
