![]() Join Date: Mar 2006
1972 burb
Hey guys John Fabris and I will be parting whats left of this 72 burb. The 5 lug stuff is spoken for and the gas tank also.
![]() Join Date: Aug 2003
Re: 1972 burb
Hatch shot?
Posted via Mobile Device |
![]() Join Date: Sep 2006
Re: 1972 burb
drivers door shipped to 70809 ? thanks jimmy may be interested in both front doors pending price how are the bottoms thanks
Re: 1972 burb
Rear floor pan? If your willing to cut out
![]() Join Date: Aug 2008
Re: 1972 burb
I need at least one of the screws that hold the rear edge of the door panel on.
Rear axle brake lines Prop valve to frame brake lines Prop valve to brake line adapter (screws into rear of prop valve pointing toward driver) Price shipped to Leander Tx 78641 Posted via Mobile Device |
#6 | |
Re: 1972 burb
I see you posted photos. 1.I see the door screws and ferrules I need. 2. I also see the adapter I need on the proportioning valve. It take around a 3/4" wrench to remove and adapts the prop valve to the 3/8" brake line threads. 3. In the detail photo of the brake booster/ prop valve and mastercylinder, a brake controller was installed at some time, so it looks like the prop valve to frame brake lines are too twisted up to use I may be wrong.(?) If not, a good tip is to soak the connections in some good penetrating oil like PB blaster before trying to remove and use good quality line wrenches to remov if you have them. 4. Not sure about rear axle brake lines...They may be more trouble to remove than they are worth. Same tip as above with soaking connections to get loose. They are not very usable if the connections get rounded off with a wrench or vice grips. I have removed lines like this in the past from trucks I parted by heating up the wheel cylinders with a torch first. They break loose easy then, but off course you have to have access to a torch. The wrecking yard near me wouldn't let me use their torch or do it for me, even though their (semi) trained monkeys were using it nearby. |
#7 | |
Re: 1972 burb
I also need four seat belt bolts if you have them.
![]() Join Date: Apr 2010
Re: 1972 burb
How much for all 4 roll up window glass? Shipped to 70546? If person who inquired about drivers door doesn't need it? Thanks, Wade
Re: 1972 burb
i would be interested in both rear inner wheel wells,,,how much shipped to 16127??? thanks sean
67 chevy short step 2wd 427 71 chevy short fleet 4x4 396 72 gmc jimmy 2wd 377 71 chevy blazer 4x4 454 69 chevy longhorn 5.9l cummins 72 chevy 400 2wd custom camper 67 chevy lwb 4x4 454-in pieces 67 chevy panel soon 4x4-400 67 gmc dump 4x4 1 ton-305 WTF!! 72 chevy 3/4 ton 4x4 burb 350 70 chevy panel 2wd 302 5 speed tko "THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!! |
Re: 1972 burb
The list grows. The body shop also lost the big washers that go on the inner fender to cab mounting bolts as well as the wiper motor mounting screws. I also need four seat belt bolts if you have them.
Re: 1972 burb
Also the 4 arm rest screws if separating
Re: 1972 burb
All locks, ignition and keys...assuming they all work properly.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: 1972 burb
What do you want for the lower sections in front of both rear wheel wells? Cut about 4" above the body lines? They look like good pieces to repicate. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#14 | |
Re: 1972 burb
![]() ![]() and i could also use the tail light sections to fix mine and remove my caddy lights..... BUT! im to far away for this to be cost effective to me lol Last edited by project 67 sub; 02-17-2013 at 06:37 PM. |
#15 |
![]() Join Date: Apr 2000
Re: 1972 burb
price and shipping to 50595 in front of passengers wheel and rear post and tail light section window down.
Wade "DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project 2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's 79 RS Camaro |
#16 |
Re: 1972 burb
upper windshield frame? im in ca can pick up and cut.?
#17 |
Re: 1972 burb
westside here are the pics and let me know exactly what part of the brake pod you need, 70 chevyolbetty front had a tree crunch it,uncle and bheltoon not much left from the rear,mel here are I think the pic you need, there are no keys I can find and when I get the doors off and weight them I can get a shipping cost. thanks Rick
#18 |
Re: 1972 burb
Ttt
#19 |
![]() Join Date: Dec 2004
Re: 1972 burb
how much for this piller on the passenger side, i need as far as you can cut up and as far as you can cut down
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
#20 |
Re: 1972 burb
price for brake booster and brackets shipped to 65101?
#21 |
Re: 1972 burb
bump
#22 |
Re: 1972 burb
ttt
#23 |
Re: 1972 burb
68 lowburb, the outside of the doors are good but they were full of water when we picked it up. right inside rusting through.
westside72, I can get you everything but don't have seat bolts Mel, lots of snow here so it will be a week before we part it ouy dins1, can get you the left rear corner but the right side panel is spoken for hilljob26, it will be a week before we get the pillar out rwade, I will let you know if I take the windows out. like to sell the doors complete 6772king, it will be a week before we part this out for the wheel wells |
#24 |
Re: 1972 burb
#25 |
Re: 1972 burb
thanks would still like to know how much and shipping to 70819 and pic of rusty inside thanks jimmy no hurry when you thaw out !!!
