Clunk after lowering...pinion angle shims?
Well I finally got the stance where I want it...ended up with 4.5 in the front & 6 or so in the rear...im not positive on the rear cause a leaf was already taken out before i got the truck & im not sure how much losing a leaf alone drops it...1-2 inches? Flip kit alone was 5 inches & stock shakles. Front was 2.5 spindles & close to a full coil cut off each spring.
So now when driving sometimes on the 1-2 shift only I get a clunk...also occasionally on take off with med acceleration. All clearances are good & absolutely nothing is making contact with anything...I did notice at ride height after lowering that 2 inches of the driveline yoke is showing now so obviously it pulled out some. Any ideas? Posted via Mobile Device |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Clunk after lowering...pinion angle shims?
What year?
lwb or swb? 1-piece or 2-piece driveshaft? Got any pics?
Ha...yeah I guess that helps. It's a 70 c-10 leaf truck, short bed, 1 piece drive line. Here are a couple pics of the truck as of now.
WOW!
Freaking beautiful truck. Got any rear suspension pics? You got something loose,... or something is hitting metal.
#5 | |
Sweet truck! Love the stance!
Have you checked the center bearing support? |
It's your yoke clunking.
Should be 3/4 inch out only. |
Could also be your pinion angle!
Did you C-notch the frame too? |
#11 | |
depending on what flip bracket you used it could be letting the housing slide around as well..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
I had to throw mine out.. they were to short and caused the housing to rotate when it was loaded/loaded.. ie shifting.. could double check yours.
#15 |
#16 |
Did you ever figure out where the clunk was comming from? Get er fixed?
1970 C10 Short Stepper with 71/72 front clip. |
#17 |
Make sure your pinion angle is right before you replace your driveshaft. Lowered trucks usually need the pinion to be raised. If the pinion is pointing down too much the yoke will be pulled out of the tranny.
Check your pinion angles with the suspension under compression as it would normally sit on the ground. |
#18 |
Motor mount clunk?
Posted via Mobile Device Posted via Mobile Device
#19 |
#20 | |
I'll prolly just get a new driveline built anyhow as I usually aim for 1 inch of the yoke being visible...2 is a bit excessive I think. Posted via Mobile Device |
