Old 02-17-2013, 03:59 PM   #1
DURG
DURG's Avatar
Porterbuilt older style hood hinge brackets?
I am looking for a set of these Porterbuilt hood hinge relocation brackets. I thought someone may have a set after upgrading to his newer style hood hinges. I posted here figuring guys may frequent this section more than the parts board?
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 02-17-2013, 10:04 PM   #2
shooter64
Re: Porterbuilt older style hood hinge brackets?
I talked to dave at porterbuilt about the very same thing and he said they are gonna start making them again, but said something about the schematics being on a frozen hard drive that needs unlocked. I like those better also compared to the cowl hinge
shooter64 is offline   Reply With Quote
Old 02-17-2013, 10:09 PM   #3
DURG
DURG's Avatar
Nate told me he spent enough time looking for the files and does not plan to offer them in the future. That's why I'm trying the forums now.
Old 02-17-2013, 10:14 PM   #4
shooter64
Dont imagine that it would be that hard to recreate if you can find a set to remeasure. I was gonna attempt it myself. The cowl hinges are a poor design in my opinion. You gotta take a hood propwith you everywhere you go
Old 02-17-2013, 10:14 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
What's wrong with the cowl mount hinges?
Keith
Convert to disc brakes.
Old 02-17-2013, 10:49 PM   #6
DURG
DURG's Avatar
Nothing if you want to cut up the cowl and weld to the hood, but I want to run tubular bracing from the front of these out and down to my front frame horns and then add a cross brace, all of which will bolt in and be removeable. I can make my own if I have to, but the Porterbuilt ones are nice and thought I may luck out and find a set.
Old 02-18-2013, 09:44 AM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
these might be a better option for someone that just wants a bolt on item.
Old 02-18-2013, 08:05 PM   #8
SCOTI
SCOTI's Avatar
x2. Been hoping to come across some as well to duplicate.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-17-2013, 11:28 PM   #9
Jeff La
Anybody got a pic of them mounted up???
Jeff La is offline   Reply With Quote
Old 02-18-2013, 08:08 PM   #10
shooter64
I originally seen them on a truck on this website and thats when I called porterbuilt. Maybe if we keep this thread going someone will make some and share the measurements
Old 02-18-2013, 08:15 PM   #11
SCOTI
SCOTI's Avatar
Hopefully, someone that already has a set can supply/offer up dimensions (since the original mfr has no intention of offering these again because they're out-dated).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-18-2013, 03:35 AM   #12
blazins10
blazins10's Avatar
I wanted a set of these too , they told me same thing about being lost
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 02-18-2013, 08:25 PM   #13
lolife99
lolife99's Avatar
They were on Dino's crew cab when it was still a single cab.
His panel may also have them.
Seems like Dino swapped them to a set of cowl mounted PB hinges.
You might pm Dino.
Keith
Old 02-18-2013, 08:48 PM   #14
Brad54
Brad54's Avatar
I guess I don't see why these would be needed...
Why would you remove the original hood hinges?
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 02-18-2013, 08:49 PM   #15
shooter64
-Brad
When ur truck has a dropmember tou need to remove inner fenders and thats where the factory hinges attach
Old 02-18-2013, 08:50 PM   #16
SCOTI
SCOTI's Avatar
-Brad
No OE inner fenders = no OE hood hinges unless there's something to bolt them to @ the firewall (that's what these pieces are).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-19-2013, 02:20 AM   #17
Captainfab
60-66 Nut
I could probably make some up as long as Nate was OK with it. Would need some basic measurements though.
Old 02-19-2013, 02:40 AM   #18
Brad54
Brad54's Avatar
Ah. No inner fenders... Much clearer now.
Thanks.
-Brad
Old 03-06-2013, 12:15 AM   #19
82swb
82swb's Avatar
Did anything come of this? I would like to find myself a set as well.
82swb is offline   Reply With Quote
Old 03-06-2013, 05:50 AM   #20
DURG
DURG's Avatar
I ended up getting a new set from another member who didn't use them because he ordered the newer Porterbuilt hinges.
Old 03-06-2013, 11:07 AM   #21
shooter64
If anyone else has them laying around ill buy them from you. Sending dino a pm didnt work lol
Old 03-06-2013, 08:21 AM   #22
tincan1966
tincan1966's Avatar
I'd sure like to find a set
tincan1966 is offline   Reply With Quote
Old 03-06-2013, 01:43 PM   #23
82swb
82swb's Avatar
Hey durg, is there any way you could send me measurements?
Old 03-06-2013, 05:54 PM   #24
DURG
DURG's Avatar
The only critical dimensions are for the hood mounting hole locations and the holes that they mount to on the firewall and how they relate to each other, which are all the same measurements as your stock inners so you should be able to get those from your stock ones. If there is something specific in addition to those measurements you need, let me know what dimensions you need.
Old 04-21-2014, 04:01 PM   #25
ChefCy
ChefCy's Avatar
bump. any body have the older ones or ended up making some that i could purchase?
63 big window lwb bagged and shaved
ChefCy is offline   Reply With Quote
