02-18-2013, 05:38 PM | #1 |
What is this part?
This is connected to red wires as you can see in the pics. one of the red wires went all the way to the rear bumper but then a PO cut it just leaving it open ended. Any help would be greatly appreciated. This started out as my brake lights didn't work. Come to find out that all the wires are spliced into from the cab and reran to the rear end but then the wires are cut back there. so rewiring today.
02-18-2013, 05:53 PM | #2 |
Gone Fishing
Re: What is this part?
top pic is a ford style starter solenoid
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
02-18-2013, 06:04 PM | #3 |
The other pics are what it's connected to. Why would someone put one on a Chevy?
Posted via Mobile Device |
02-19-2013, 06:54 AM | #4 |
02-18-2013, 06:18 PM | #5 |
My have been used as a relay to run power to a camper or topper. Is there a switch in the cab that controls the relay?
Fuzzy |
02-18-2013, 06:50 PM | #6 |
02-18-2013, 07:45 PM | #7 |
That is probably a continuous duty solenoid but from the looks of the wiring it may very well be a starter relay being improperly used. Charging or powering a camper or trailer would be my guess as well. No matter what clean up is needed. Might be best to start with a factory wiring diagram from the service manual for your model year and work through it one circuit at a time.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-18-2013, 10:49 PM | #8 | |
That's the intention. Thanks and I think that's what it was probably used for. I'm cleaning it up as I can. Posted via Mobile Device |
