Old 06-15-2003, 01:52 AM   #1
Low69CST
Finished my dash, oil pressure guage question
I got my dash put together today, looks pretty good especially considering the new ones are bout 500 bucks. I should have some pics in a few days. I noticed that the oil pressure guage is mechanical, I thought they were all electric. What kind of line do I need to run to it? I have some of that plastic capilary tube that came with an old set of sunpro's I bought to break in my engine. Can I use that stuff? Its a whole lot more easy than using steel line.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-15-2003, 01:56 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
As long as the fittings all fit up nice you could use it. I think that steel or sttel braided would be better though. Just leave enough slack in the engine compartment for the engine to move around from the torque.
Side note, I don't think plastic tubing is NHRA legal for drag racing if you intend on takin yours down the 1320. (1/4 mile)
Old 06-15-2003, 01:57 AM   #3
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
the poly line has been known to break, go with the copper line, you can get it at a good parts store..
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 06-15-2003, 08:03 AM   #4
hanssolo
hanssolo's Avatar
I'd go with the copper line too. Good insurance. It bends easy and reinforces ground to the engine.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 06-15-2003, 11:04 AM   #5
Longhorn Man
The engine should be grounded directly with the battery cable. If you ground to the frame and use ground straps to groiund it, you'll end up with starting problems becouse of the amperage draw.
Copper can be easily bent without a bending tool too, just use the pullies on your engine. The alt pully for a smaller tighter bend, and the crank or water pump pully for a more gradual bend.
