02-22-2013, 03:01 PM | #1 |
Can someone please tell me how to replace a 3 speed transmission and clutch?
I have a 69 GMC pickup and it needs the tranny replaced. I really need to know how. So if someone could post a step by step process thatd be very helpful! Thanks!
02-22-2013, 03:56 PM | #2 |
Re: Can someone please tell me how to replace a 3 speed transmission and clutch?
Its a 292 3 speed. Thanks!
02-22-2013, 04:07 PM | #3 | ||
"I ain't nobody, dork."
A good service manual breaks it down step by step. Haynes or Chilton...
Gary
02-22-2013, 04:14 PM | #4 |
You realy need a manual but i'll help you through it. Remove the drive shaft at the rear end & slide it out of the trans. It a good idea to drain the trans. unless you want a puddle of grease in your lap. Remove the clips that hold the shift rods to the trans. Tie the rods out of the way. Remove the pan under the clutch & remove the lower trans mount bolts. They go in from the front. Remove the upper trans bolts from the top of the trans. If you are a pretty stought fella or otherwise in good physical shape you can slide it out & put it on the ground. It weighs about 75 lbs. To remove the clutch, remove the bolts assesable & turn the engine & remove the bolts as they come down. Slide the clutch out the bottom. You may have to push the disc up into the houseing & pull the pressure plate out first.
02-22-2013, 05:27 PM | #5 |
reprints of GM factory service manuals are a great cheap investment and a good way to do things right the first time// they pay for thierselves with one job done correctly the first time
most vendors here have them cheap or you can surf ebay for a cheap one too
02-22-2013, 05:43 PM | #6 | |||
My advice would be to find a buddy or two that have some wrenchin' skills and ask them for help. I know everybody needs to learn sometime... but it's better with help on a major part like a transmission and bellhousing. Gary
02-22-2013, 05:30 PM | #7 | |
I am a Referee of life.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-22-2013, 08:50 PM | #8 |
I have a haynes 420 manual i didnt find how to do this.
