02-23-2013, 03:37 PM | #1 |
1978 engine swap, help
I have a 1978 Sierra with a 400 small block that is Preety much toast ( loud knock turned to violent banging noise). Anyways I got a newer 350 tpi engine for free, it was in a 68 camaro and was pulled about a year ago... My question is how/what needs to be done to the 350 so I can drop it in my truck that is carburated. What parts will I need, and are the 400 and 350 small block parts compatible?
The 350 is in really nice shape like new, it came out of a restored camaro that my employer owned. He put 454 in when he bought it. Like new 350 I would really like to put in my old beast. Any info is appreciated thanks Posted via Mobile Device
1978 sierra grande full time 4wd |
02-23-2013, 04:17 PM | #2 |
Re: 1978 engine swap, help
Do you want it carb or injected? It should fit right in with minimal work.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
02-23-2013, 04:20 PM | #3 |
As much as I'd like a tpi engine I think it would be easier to dumb down the engine than put a computer in the truck. I am open to either option, want to keep the work to little as possible. Thanks for your response
02-24-2013, 04:39 PM | #4 |
I would keep all the front pulleys from the 400 and swap the manifold/carb/distributer from the 350.
You can do it in a day with a friend if you are quick (me and my brother have done it). Take two days and go slow you will be fine
02-25-2013, 03:09 AM | #5 |
Are the manifold and distributor compatible from the 400?
I was talkin to the mechanic where I picked up the engine he said I am going to need to change the exhaust manifolds to fit, the dip stick is on the opposite side on the 350 I am fully confident to do the swap just want to cover all my angles before I start Posted via Mobile Device
02-25-2013, 05:41 AM | #6 |
tha center 4 bolts on tha tpi are @ a diff. angle than tha one one your 400..you could enlongate tha holes & use angled washers or eddelbrock make a carbed intake jus to fit those heads
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
02-25-2013, 04:01 PM | #7 |
I've read about the centre bolts
On some other threads, is it the same difference if those holes are drilled out properly compared to a proper fiting new manifold? Also will the distributor work from the 400? Posted via Mobile Device
