Old 02-23-2013, 05:51 PM   #1
AirSpeed
AirSpeed's Avatar
Cargo light mounting position
I'm ordering a cargo light for my 72, do any of you have a measurement to position it? Does it require any cutting to install or just a couple screw holes and one for wires? I'm going to make it a third brake light as well. Thanks!
AirSpeed is offline   Reply With Quote
Old 02-23-2013, 05:57 PM   #2
Scott>72-GMC
Scott>72-GMC's Avatar
Re: Cargo light mounting position
Not sure about aftermarket but originals were cut in
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 02-23-2013, 06:03 PM   #3
AirSpeed
AirSpeed's Avatar
I'm kinda hoping the aftermarket light needs no cutting! I hate cutting around my newer paint! I'll probably slip and take off some paint! Anyone buy an aftermarket cargo light? Another thing, are the repops plastic or metal?
Old 02-23-2013, 06:05 PM   #4
Scott>72-GMC
If you do have to cut. Outline with painters tape. Will prevent scraping
Old 02-23-2013, 06:10 PM   #5
AirSpeed
AirSpeed's Avatar
I'll probably cut a template out of some 1/8" plywood and tape that on! I don't trust myself enough to use tape as a shield! Im good at this stuff but with my luck ill get too confident and destroy the back of my cab!
Old 02-23-2013, 07:51 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I'm sure you will have to cut and drill holes.
Here are the measurements...
LockDoc
Leon
Old 02-23-2013, 07:53 PM   #7
AirSpeed
AirSpeed's Avatar
LockDoc
Perfect! Thank you!
Old 02-23-2013, 07:55 PM   #8
LockDoc
LockDoc's Avatar
Originally Posted by AirSpeed View Post
Perfect! Thank you!
No problem. Just take your time and you will be OK...
LockDoc
Leon
Old 02-23-2013, 08:33 PM   #9
SS Tim
SS Tim's Avatar
Assembly manual was a good call Leon. Here is a link that may be helpful to your install as well. http://67-72chevytrucks.com/vboard/s...d.php?t=528116
SS Tim is offline   Reply With Quote
Old 02-23-2013, 10:02 PM   #10
LockDoc
LockDoc's Avatar
Thanks Tim. Do you have the assembly manual on CD? The nice thing about it is you can do a search in it then just copy and paste the page.
LockDoc
Leon
