![]() Join Date: Apr 2005
Spec me an LS cam!!!
I'm trying to figure out what cam/springs to put in my new 6.2 motor. The engine is out of a 2013 Camaro SS (only 135 miles) and will have the factory 6L80E behind it. I'm plan on putting a TVS 1900 Maggie on top and will be deleting the AFM/VVT with a kit from TSP. I don't want to get crazy with the cam and would like to keep the stock converter if possible. Please let me know your thoughts and suggestions. TIA
EDIT: Some more pertinent information. The truck weighs approximately 3500 lbs, 4.11 gears with 31" tall tires. I will probably run a/c.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-27-2013 at 09:59 AM. |
Re: Spec me an LS cam!!!
Martin @ Tick will spec you a custom grind for $400 - same you'll pay most anywhere else for an OTS grind.
That would be my recommendation. Or Ed Curtis. |
meowMEOWmeowMEOW
If your running the VVT delete from TSP, I'd give them a ring about a spec for your combo. I've been pretty happy with TSP and its service and product.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | ||
Does any one have a guess on what the stock stall converter is on this 6L80E? Any thoughts on this CAM? http://www.texas-speed.com/p-245-tex...-camshaft.aspx
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
http://www.tickperformance.com/
http://flowtechinduction.com/ Martin @ Tick specs out customs for $400. Same you're paying for an OTS grind from TSP and his cams make great power. Ed is the godfather, he's been in the business for a LONG time and really knows his stuff. Me personally, with an F/I app I'd have Ed do it. Another $50 and you will know you're not leaving anything on the table.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
#6 | |
219/235 113 LSA 607/621 He said this will give me a little lope, plenty of power and I can run the stock torque converter. Thoughts??
#7 | |
Call Martin or Ed. Call Martin or Ed. Call Martin or Ed. Call Martin or Ed. Call Martin or Ed. Call Martin or Ed. Call Martin or Ed. Call Martin or Ed. Call Martin or Ed. |
How many miles a year are you going to drive this?
I am taking it, you are much more concerned about street manners than how fast it goes down the track? What rpm are you wanting to spin too? What fuel are you going to run? Stock heads? That TSP cam is more suited for a na LS3. Posted via Mobile Device
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#9 | |
![]() ![]() ![]() ![]() Call who you want but those guys make a living picking lobes and they do it very well. Both can set you up with all of the correct components to match the cam they design. |
Comp LSL lobes or XER lobes the LSL will give you more lift than the XER. The com premises are wearing springs and guides a bit faster with a stock rocker.
224/232 with a 106icl + 4* advance ground in. This will give you very similar curve to an ls6 cam just a lot more power. Should peak right around 6200-6400 with a ton of tq down low. Posted via Mobile Device
meowMEOWmeowMEOW
Hart, for the life of me I can't remember the dude's name over at TSP that I dealt with. I met him in person out at LS fest a while back.....unfortunately telling you what he looks like won't do much.
You could also talk to Allen at Nelson Performance. He does alot with turbo and supercharged applications.
After many questions and a lot of good advice (thanks everyone!), here is the cam I ended up ordering:
http://www.summitracing.com/parts/cca-54-45311 I'll also be upgrading to dual valve springs, hardened pushrods and a trunion upgrade for the rocker arms (as well as deleting the AFM and VVT, ).
