02-26-2013, 04:03 PM | #1 |
quadrejet, transfercase mount,blazer tank sender,oil line
i wont need these,time to move em. all these are or best offer
transfer case frame mount, has been blasted and painted,comes with new poly mounts and stock rubber mounts 50 shipped SOLD quadrejet carb this was pulled from a running driving truck about 4 months ago.. numbers on carb are 1708029 2 1057C0 CY K 50 shipped oil line 10 shipped SOLD blazer tank sender, this was only used about 4 months..30 shipped SOLD
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 Last edited by hilljob26; 02-27-2013 at 03:58 AM. |
02-26-2013, 04:18 PM | #2 |
Re: quadrejet, transfercase mount,blazer tank sender,oil line
I'll take the oil line for $10 shipped. Paypal? Jamie 71 Longhorn
02-26-2013, 04:33 PM | #3 |
ok, pm sent
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
02-26-2013, 06:12 PM | #4 |
one set closer
I'm interested in the sending unit. Is it in good working condition?
Posted via Mobile Device |
02-26-2013, 06:39 PM | #5 |
it was when pulled,,have no way to test it as of now
02-26-2013, 08:15 PM | #6 |
according to the numbers 170-80-2-9-2, that Q-jet is a 1980, 49 state emission legal, auto trans spec carb. the 9 is a hokey number (Rochester didn't always follow their own rules) but we can infer that is a chevy unit by the 90 deg fuel inlet. so you have a good carb there for a driver.....1977+ with all the improvements plus electric thermostat, but it is a fully mechanical carb so an easy install-upgrade on one our classic trucks!
02-26-2013, 08:25 PM | #7 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
On the Q-jet, how is the throttle bores, are they worn or sloppy, has the idle mixture plugs been knocked out? and the vacuum pod pull off hold vacuum? thanks
02-26-2013, 11:04 PM | #8 |
doesnt appear to be sloppy or worn, the idle mixture plugs i do not see, just the 2 rectagular heads inside the hole for adjutment, and the vacuum module appears to be working well,,when i pushed it in, you can hear it push air out in the carb,and it came back slower then i pushed it in,,i hope this helps
02-26-2013, 10:35 PM | #9 |
one set closer
Ok I'll take it pm me your PayPal
02-27-2013, 01:43 PM | #10 |
ttt
02-28-2013, 11:17 AM | #11 |
Do you still have the carb?
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
02-28-2013, 02:04 PM | #12 |
yes,,the carb is still for sale
