Ralroad truck ? one ton?
I was told that this is a rail road truck, and is a one ton. I think it is a 64. can any one shed some light on this old girl
#2 | |
Re: Ralroad truck ? one ton?
ron |
Appears to be a Scot Built or similar. A company bought GM trucks, took them to their factory and turned them into crew cabs, extended cabs, etc. There were several companies that did this. Various bed lengths were available. It appears you have a stock length frame and they shortened the bed to accomodate the cab stretch. Some had lengthened frames and larger boxes.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Judging from the color is belonged to the Union Pacific Railroad. Those trucks typically had the UP Shield on the door. Any signs of that?
What I noticed right away iss the bed is very short in front of the rear wheels. Is there a back door on the driver's side?
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#5 | |
ron |
It has a hydrolic switch on the dash that says rase and lower. I have not gone under the truck yet. It only has 2 doors GVW is 7500 trim STD WB 127 paint RPO 519AA.
![]() Join Date: Aug 2004
there were 5 companies who were contracted by GM to stretch those and suburbans. Stageway was one of them and also Scottbuilt was too. their were 2,3 and 4 door crew cabs. mostly used for fire fighters, railroad and logging. they are not very comon at all and are pretty sought after. the crew cabs more that the 2 or 3 door ones.
here is my dad's crew, for some inspiration...
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#8 | |
-Jason '66 C10 LWB 2 BBL 283 w/ T-5 '90 V1500 Suburban TBI 350 w/ 700R4 |
The cab was originally on a Chassis/Cab, then the dealer put a wrecker bed on it when the original person who special ordered it failed to pick it up at the dealer. That's where the window was made larger for a better view,the dealer used it for years and years until it went out of business ( small town Chevy dealer in the mid 80's IIRC) the shop foreman bought the truck for nostalgia and eventually for the BB in her ( I think 409) I found her in 2000 sitting in a field all lonely and wanting for a new home. I bought her and then gave her to my dad when my ex wife nuked over the purchase. He built her over 4 years, new chassis and everything.
Who Me?
Usually RR truck would have a custom wheel that was real narrow to ride the rails. Im not sure if those stock wheels are narrow enough for that, but then could have been replaced too.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#11 | |
![]() Join Date: Mar 2012
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
the doors did have some half circle shield on them at one time you can just see the outline looks like the doors were repainted at one time. I dont think this truck was set up to go down the tracks. The lever on the dash is hooked into the brake lines. I see no signs of a PTO any were it is a 235 engine a think
#13 | |
Who Me?
would probably be the 250 or 292 engine if its a straight six. 235's were about done in 62 with the 230 coming in 63 and the 250 shortly after. The union pacific railroad logo is a shield i believe. My great grandfather was a conductor on the Pennsylvania RR after WWII
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#15 |
the numbers over the starter CON2 H24 then in the middel of the block ther was 3851659 some one took the distrbuter
#16 |
H24 should translate to August (the 8th month) 2nd, 1964.
CON2 means something like conveyor #2. |
#17 |
Thanks for all the info. you guys are grate
#18 |
Can you get any more pics? Maybe some underhood and interior. Its cool to see these trucks in their different variations.
#19 |
moor photos
#20 |
That engine is the 292. Has the large side plates. Great engine, lots of torque but can be a gas hog.
#21 |
So I have a 3/4 ton 292 engine 4 speed 1964 Union Pacific Railroad extended cab 2 door standard wheel base 5 foot bed. I have to decide what I am going to do with this truck. I have 3 other projects now 1937 Hudson Teraplan truck a 1941 ford COE an a 37 ford truck. I like this truck but it needs a full restoration. Should it be left stock Or is it better to go nuts on it? I have a cat diesel in a Kodack that has 59k on it and it is 6 k a year to register it in CA. I think it would make a good donor for this truck.
#22 |
IMO, the best thing to do with it is kind of go both ways. what I mean is more of a resto-mod than a restoration, the reason I say this is because in their original form, they arent very attractive or useful ( other than to us purists). but if you made it a 1ton with the cat and dual rear wheels, maybe even bigger if you have a need for it.
a 3/4 ton or 1/2 ton would sell better if you needed to. You can send it to me and Ill build it! hint hint nudge nudge!!!!!!
#23 |
I think you may be right. the cat drive train and a 5th wheel hitch. would save a ton on regustration. I have a shop and some tools. I have done a fue cars. If I keep it I will do it but, if it gos down the road. I could sale the Kodiak and the truck together and finish some of my other projets. I could put them all up for sael and keep what did not sale. I dont wont to be a horder. My girl freind totaly thinks I am. the hudson and the COE are prity far along. I have not started on the 37 ford. The coe will be a good tow rig but this truck with a cat in it would be grate but a lot moor work.
#24 |
I agree with Clyde65...do what you want with the truck. Its an interesting truck and I say have fun with the build. I think it'd be pretty cool w/a diesel in it personally.
#25 |
I soled the 37 ford today. he will pick it up on Saturday. I have a 56 ford for sale as well see witch one go,s first and build what is left. I will have a jump start on the money to build with. I think if the club cab survives the cut I will find a donor with good sheet metal. I am looking at the cat 330 engine in my Kodack diesel I would have to modify the pan and intake to get it in the 64. Dus any one know of any one that has done this swap?
