Old 02-27-2013, 12:11 PM   #1
smoknbarrels
Registered Mail
smoknbarrels's Avatar
What does transmission have to do with park brake cables!?
I am trying to order a full set of park brake cables for my truck, but since i have an aftermarket trans installed the guy at inline tube says thats custom and wont fit...
Last i checked, the parking brake wasnt connected to the transmission!?
I see in their catalog that they do spec out different transmissions, but what does this have to do with parking brake? Is it really that big of difference of fit if I installed a 5 speed manual?
smoknbarrels is offline   Reply With Quote
Old 02-27-2013, 03:15 PM   #2
JDL
JDL's Avatar
Re: What does transmission have to do with park brake cables!?
Auto trans has the crosmember at the back of the trans so the cables have to be routed through it.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 02-27-2013, 08:01 PM   #3
SS Tim
SS Tim's Avatar
Mock up a park brake cable with a wire and route it like the stock setup in the service manual then measure it. If a stock application is really close then adjust the guides to fit the closest. If it is going to be several inches a custom cable might be best or if you can crimp up your own. LMC's catalog has the lengths for you.
SS Tim is offline   Reply With Quote
Old 02-27-2013, 08:27 PM   #4
JimKshortstep4x4
The TH 400 crossmember has the cable routed through one or two loops that attach to the crossmember. Here is a picture of a mocked up crossmember as used in a TH 400 application. Other transmissions may not have any effect on the cables but I am sure that there is a spot in their order form for the type of transmission the vehicle has.
It is pretty easy to make up the intermediate cable so that is what I usually do.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-28-2013, 01:40 AM   #5
smoknbarrels
Registered Mail
Yea i looked in lmc book, but didnt show how it connects to the cross member, i ordered one, if i have to weld a loop or something to my custom crossmember its no problem, i just didnt know why there was a difference in the kits.
Thanks!
Old 02-28-2013, 01:46 AM   #6
KrazyRay
KrazyRay's Avatar
I noticed that the equalizer rod is longer on the big block/th400 trucks. I guess that would make the cable a bit shorter.
KrazyRay is offline   Reply With Quote
Old 02-28-2013, 02:04 AM   #7
SS Tim
SS Tim's Avatar
The shorter cables are to clear the rear trans crossmember. You are probably going to need to start with a short cable and fab an equalizer point similar to the TH400 or 4x4 installation off of the crossmember. My reference was to the LMC catalog was for lengths and service manuals for routing.
