Old 02-27-2013, 03:42 PM   #1
Biscuit240
Loses power when downshifts
Got a 70 c10 With a v8 and an automatic tranny with a new quadrajet and new plugs and wires. Truck runs great until you start climbing a long hill. As soon as I press tge gas to compensate for the lose of speed the truck will downshift but gains no power or speed. In fact the more I let off the gas the more it will accelerate until it up shifts again just to start the process all over again.
Any ideas?
Biscuit
Biscuit240 is offline   Reply With Quote
Old 02-27-2013, 03:52 PM   #2
hyatt
Re: Loses power when downshifts
sounds like a clogged exaust
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 02-27-2013, 04:22 PM   #3
Biscuit240
Hmm the exhaust seems to flow freely. Strong acceleration in lower gears when starting out but falls on its face when I'm going uphill and downshift.
Old 02-27-2013, 04:33 PM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Sounds like it might be a lean condition. What happens on level ground with quad open.. does it bog? If it does might be float set low.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-27-2013, 06:39 PM   #5
Biscuit240
Seems to run strong on flat ground. Pulls real hard in second. Seems slow to downshift alot though.
Old 02-27-2013, 08:48 PM   #6
hjewell2
hjewell2's Avatar
according to your statement it sounds lean as if the metering rods are stuck.
sometimes the power piston sticks on the quads.
hjewell2 is offline   Reply With Quote
Old 02-27-2013, 09:11 PM   #7
Gumby
Gumby's Avatar
id pull the top plate n check the floats [n other stuff], and install a set of brass floats from napa while your in there. [fyi GM made it so you can do that without removing the whole carb]
Gumby is offline   Reply With Quote
