Old 02-27-2013, 07:51 PM   #1
cwsohm
cwsohm's Avatar
3 point seat belt roll bar attachment
I've seen a lot of posts regarding attachment of the seat belt shoulder strap anchor to the roll bar in a blazer, but most of them discuss drilling and welding. Has anybody found a clamp set up that will work? I came across a heavy duty pipe clamp that is rated at 749lbs on ebay.
http://www.ebay.com/itm/DOUGHTY-HEAV...item4d0396e463
Seems like this could be easily modified to attach the shoulder harness of a 3 point belt to a roll bar. I'm thinking it would be strong enough if it is rated at 749lbs, and would allow you to easily adjust the height if need be. Thoughts?
cwsohm is offline   Reply With Quote
Old 02-28-2013, 11:02 AM   #2
fun in dirt
fun in dirt's Avatar
Re: 3 point seat belt roll bar attachment
You have to take into account the shock load that would be placed on this clamp in an accident. Fall protection anchors in industry are required to support 5000lbs (thats w a 2x safety factor), because your body weight + force on it in accident puts alot of stress on this one anchor point. But I'm no engineer, so thinking about that with some everday math tells me even a seatbelt having 3 anchor points needs be able to withstand at least1666lbs (=5K/3) of force at each point.....so no I wouldn't recommend using those.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 02-28-2013, 11:09 AM   #3
cwsohm
cwsohm's Avatar
I agree with your thought process... Just seemed like a more stout option than some of the exhaust clamp options described in other posts... There has to be a better bracketed solution than drilling out and welding to the roll bar.
