![]() Join Date: Nov 2010
A/C Parts
Bought a factory A/C system and was wondering If I could get pictures of a factory A/C setup the best you can of inside the cab as well as going into the firewall and heater box. And also Where is the best place to buy parts for them? Such as POA Valves and all of that. Thanks
Re: A/C Parts
the assembly manual has lots of info. I bought some parts from Old Air in TX.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: A/C Parts
Look in the FAQ section There information on air conditioning.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Re: A/C Parts
Im looking for some pictures of what goes where. Im going in blind with this
Re: A/C Parts
60-63 or 64-66?
Re: A/C Parts
Re: A/C Parts
64-66
Posted via Mobile Device |
Re: A/C Parts
Here are a few firewall shots and a dash shot.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
Re: A/C Parts
There was just a full installation manual posted on here that I printed out, so you should be able to find it.
![]() Join Date: Jan 2001
Re: A/C Parts
Here is that excellent thread of detailed installation instructions from the FAQ section.
http://67-72chevytrucks.com/vboard/s...d.php?t=559436 I am doing the same retrofit but luckily mine is an original ac truck and I have 3 other factory air parts trucks for reference and parts. I plan to reuse the original ac evap core and have o ring with nut fittings tig welded on to the outputs for new rubber ac lines to attach. There is a line/condensor/dryer kit available from LMC and other truck sources but I dont know if that is what I want. I plan to use R134 and to go to a larger late model crossflow ac condensor and new dryer all with the new style fittings versus the old clamp originals also. Possibly add a pressure cutout switch too.The bypass valve is available locally at most auto parts stores but a good source for most all these ac parts is Old Air Products from what I have seen out on the net. I plan to be doing this all over the next several months as my truck is tore to bare pieces now and starting return assembly. My original 327 engine renovation is the holdup as my old timer machinist is buried in irrigation motor rebuilds till April. Three of my 1966 ac trucks all came from Kansas in the last couple of years. Great Bend, Wichita, and Manhatten areas. So were not too far north if you need to come check out mine. Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 factory #'s V8 stepside project '72 Cheyenne K20 50k original '72 CST Blazer K5 owned 30+yrs '73 Sierra swb 4x4 '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" Last edited by HOTFUN; 03-01-2013 at 11:41 AM. |
Re: A/C Parts
Well what I have is an under dash set up that was dealer installed it looks like but I just don't know if I can cut a whole in the firewall and do it? I e never ran across a factory air can before so if I make this one right then it'll be the first. Those pictures helped a lot but has anyone ever cut a hole to make it work or is that not possible?
Re: A/C Parts
Picture posted are exacly what the truck it came form look like.should go right in. I can take a template of cardboard paper and mail it to you.
Re: A/C Parts
That would be helpful
![]() Join Date: Aug 2008
Re: A/C Parts
if you use the accessorie book it gives the places to cut there are dimples on the firewall for the engine compartment. the template would be great for the dash area . good luck
#15 |
Re: A/C Parts
Would that be in the assembly manual or which book are you talking about?
#16 |
Re: A/C Parts
accessory installation manual you can buy repos manuals for 20.00 ebay . the were used by the dealers to install accessories such as clocks, ac, armrest,litter containers ,etc.
