Driveshaft issue
Okay so I'm in the process of pulling my transmission and I'm having a helluva time trying to get the driveshaft to drop from the pumpkin. I have the c clips removed, tapped on it with a hammer and pried on it with a bar to get it to slide forward enough to drop but can only get it to move maybe an 1/8". Its a single piece driveshaft and has a flip kit in the rear so I'm thinking maybe with it being flipped the slip yoke is already pushed into the transmission as far as it can go? If this is the case what can I do to get the driveshaft out?
Parts and more parts
Re: Driveshaft issue
You can loosen the engine mounts and move the whole engine forward a little or loosen the rea axle and move it towards the rear of the truck. What I would think hard about, though is that your driveline is too long and it may be causing some damage to the rear putput shft components as you drive it and hit bumps in the road. You need more play than an 1/8" clearance.
Frank |
Id jack the truck up on jack stands put a jack under the diff drop one end of the leaf springs and lower the diff tell the driveshaft will come out.
#4 | |
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
sawzall
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
you flip kit should have a hole to move it aft 1". you need to do that anyways. you will beable to remove the shaft after that
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
