06-16-2003, 04:05 AM | #1 |
Holley Carb Experts Please Step In...
I'm trying to figure out how to tune my Holley 600cfm 4160 Carb. (Vacuum Secondaries, Electric Choke). A good friend of mine, let me borrow his $500 Wideband OČ Sensor, and I hooked it up to a custom made OČ Sensor bung on my exhaust (The sensor is heated, the bung is right behind the header collector), and it showed my tune was WAAAY off! I finally got the idle set @ 750rpm, with an A/F Ratio of 14.2:1. Then, when I did a WOT test, it showed, @ WOT (from 3000-5000rpm) it was at 11.5:1. Isn't that running a little rich? Shouldn't the A/F Ratio @ WOT be around 12.8:1?? My question is, how do I lean out the carb @ WOT? Do I need to adjust the float levels in the secondaries? Thanks guys!
06-16-2003, 07:35 PM | #2 |
Adjust the floats so that the fuel level just reaches the sight plug and leave it there for eternity. Change to smaller secondary jets to lean it out. I have tuned many a holley but never with a tool like you have. Sounds pretty trick.
06-16-2003, 09:25 PM | #3 |
Go here and you should find every thing you need to know hope this helps . http://holley.com/HiOctn/TechServ/TechInfo/FMCTech.html
06-17-2003, 10:54 PM | #4 |
5 day ban, learn to behave.
did you check it under load at WOT? you dont have air injection or any exhaust leaks do you?
