Old 03-01-2013, 03:02 PM   #1
TG114
what is every one with bags running for air systems
Just put static bags in my 66. So I'm wondering what everyone with bagged rigs is running for tank and compressor setups. thanks.
TG114 is offline   Reply With Quote
Old 03-01-2013, 04:08 PM   #2
jimmydean
jimmydean's Avatar
Re: what is every one with bags running for air systems
Last time I used a small Thompson compressor and 5 gallon tank. This time I am using 2 Viar comps and a 7 gallon tank.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-02-2013, 10:31 AM   #3
creep
Registered Loser
creep's Avatar
I'm using a Viair 480 compressor and a 5 gallon tank. I will probably add another tank and compressor one day though because after I lift the truck up once the compressor has to fill the tank again before I can lift it again.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 03-02-2013, 10:39 AM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Im running one viair 380 and a 3G tank. Manual valves and mostly 1/4 lines.. Just the rear is bagged so far.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-02-2013, 10:57 AM   #5
blazins10
blazins10's Avatar
2 viair 480s ,2 3 gallon tanks , accuair manifold with mufflers
accuair controller with pressure switch , 3/8 line
accuair water traps , alot of accuair but its lifetime warranty
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 03-02-2013, 05:35 PM   #6
joedoh
joedoh's Avatar
engine driven compressor, 5 gal tank. I have had 8 airbagged rides and the last two had EDC. electric compressors are ok, but I am never going back, fills a dead empty tank in 2 minutes and you have enough air to drive in 20 seconds.
I also run manual valves, its pretty uncomplicated. I have used all kinds of valves, SMC, Blitzluft, manifolds from ART and AIM, and the manuals give me the least problems. the only drawback is the speed.
Old 03-02-2013, 06:25 PM   #7
blazins10
blazins10's Avatar
by all means if u can put a engine driven one on do it !!! by far the best
my 63 will get one here soon but my other bagged trucks just dont have the room
Old 03-02-2013, 09:41 PM   #8
ol_skool_chevy
ol_skool_chevy's Avatar
what type of engine driven compressor...I have never seen one before...But makes sense..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 03-02-2013, 10:12 PM   #9
blazins10
blazins10's Avatar
just google york 210 compressor
Old 03-02-2013, 10:34 PM   #10
joedoh
joedoh's Avatar
old york air conditioning compressors. Here is the one on mine.
Old 03-03-2013, 12:41 AM   #11
TG114
where do you get your manual valves all i can find are two way or electric.
Old 03-03-2013, 01:30 AM   #12
blazins10
blazins10's Avatar
i dont have an answer for that , accuair manifolds
are all that i own or my shop installs anymore , its been close to
3-4 years since ive done a brass valve setup , its just saves alot of time on install
and no worrys about leaks
but in 1997 when i bagged my blazer i used master image customs manual valves then
Old 03-03-2013, 01:30 AM   #13
joedoh
joedoh's Avatar
I bought up all the old school manuals I could find but littl larrys still makes them new
you can also buy firestone manual paddles for about $14 ea but they are only 1/4 and pretty slow, even by manual valve standards.
Old 03-03-2013, 01:37 AM   #14
blazins10
blazins10's Avatar
ok ... so i dont get it ? why would u pay 360$ for manual
valve setup ? accuair is like 50$ more , i think u would spend the extra in air line
to get it in and out of the cab
not knocking anyones choice but ... i been down the manual route
and dont plan on going back
Old 03-03-2013, 03:24 AM   #15
joedoh
joedoh's Avatar
the accuair manifold alone is 140 dollars more. air line is .36 ft, so to spend 50 bucks you would need to use almost 140 extra ft of airline, at 140 bucks you would have almost 400 feet of airline to be even. and you still need switches, and wiring, and check valves. and if you want to control the speed of an accuair, you need the 1000 dollar PWM controller, with a manual system you just open the toggle a little less.
I have had all types of electric setups. manuals are simpler and more reliable.
Old 03-03-2013, 11:28 AM   #16
blazins10
blazins10's Avatar
i paid 380 for the accuair manifold , the controller is 300 but u can use regular switches
its like 2k if u run the e level setup , we were talking just valves i can put electric valves in for the same or close to as manual valves
Old 03-03-2013, 12:20 PM   #17
joedoh
joedoh's Avatar
Its super cool ou got a good deal on the accuair manifold but for everyone else its still 500, and you still need check valves and a switchbox.
you could buy electric valves cheaper, yes, figure 33 ea for 8 3/8 SMC electrics is about 270, you'll still need check valves and a switchbox, and speed controllers if you arent happy with the fill or dump speed. The little larry valves dont come with output fittings, BUT they are 3 way valves so you only need inlet and outlet, the electrics will need some tee fittings between. Not getting nitpicky, but its the nickle and dime stuff that makes it an apple to apple (total cost of manuals v total cost of electrics) instead of apple to orange (cost of 4 manuals vs cost of an electric manifold or 8 individual electrics)
If you are happy with electrics thats great, but not everyone will get an accuair for 380. not everyone will want 6-9-16 switches when 4 will do. for daily driving I want it simple, my choice is manuals. I like that I can vary the speed up or down as I feel like it, something you cant do with electrics.
Old 03-04-2013, 12:17 AM   #18
DLOE65
DLOE65's Avatar
check mine out.
DLOE65 is offline   Reply With Quote
Old 03-04-2013, 06:20 PM   #19
kieth
kieth's Avatar
I only have bags on the rear so I installed a tank with one valve and a 2 way switch, 2 schrader valves, keep air in the tank, adjust as needed. Inexpensive and it works. I of course do not have a slammed truck. Kieth
kieth is offline   Reply With Quote
Old 03-04-2013, 06:51 PM   #20
gbrown
gbrown's Avatar
Do you have a build thread or a thread with more info on your setup? This sounds exactly like what I want to do...
gbrown is offline   Reply With Quote
Old 03-04-2013, 09:50 PM   #21
joedoh
joedoh's Avatar
you can do it a lot easier with some Firestone paddles and you can still use the reserve tank the way he describes. just make sure you dont think there is a weeks or a days or even more than a single use amount of air in the tank. one lift would be about it.
I like your valve DLOE65, but they looks as slow as Firestone paddles...
Old 03-05-2013, 11:34 AM   #22
kieth
kieth's Avatar
I did mine this way to keep the cost down, after I finally get the ride height settled where I am going to keep it then it can be easily changed to a more complicated system.
air tank on side of frame
1. 1 line coming in from a schrader valve (located on rear lisc plate bracket)
this line allows the tank to be filled up from a compressor (in my garage)
2. coming out of the tank 1 line coming out to a air control valve(12v electric operated (normally closed----opens when toggle switch is lifted up this adds air to the bags and raises the truck)
3. inline behind the 1st valve is another 12v valve that is used to let air from the bags (when the toggle switch is pushed down it exhausts air--lowers the truck)
4. also in line with the line that contains the 2 valves is another schrader valve that can be used to add air to the bags in case of you need to air the bags up manually.
If you will send me a PM with your phone number & email I will take some shots of it this weekend on my iphone and send them to you. Kieth
here is a link to my build , this link only shows the bags as we installed them initially, later we took out one set of the cages......
http://kieth.smugmug.com/Trucks/66-G...3713&k=s6rzRrs
Old 03-11-2013, 12:24 AM   #23
westcoast5
I have a EDC awesome!
Bryan
1966 SWB BBW "SICKT6"
Accuair|Porterbuilt|Bodied|Shaved|Z'd|350 with minor goodies|5 lug|front disc|3.73 rear|CPP power steering/brakes|few more goodies| thanks to C10Clubapparel
westcoast5 is offline   Reply With Quote
