Old 03-03-2013, 07:52 PM   #1
frankyjoet
Cool electric oil gauge 73gmc
the gauge needle is at 3'oclock. pin #6 is being used by the oil gauge and the temp gauge. the temp gauge works but not the elec oil gauge. pin#6 is attached to the oil sender wire, pin#5 gets ign power from the power gauge wire. thanks for any help. for your info this PCB is from an 89.
frankyjoet is offline   Reply With Quote
Old 03-03-2013, 09:06 PM   #2
b454rat
Re: electric oil gauge 73gmc
73 doesn't use electric oil gauge, it's mechanical.....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 03-03-2013, 09:26 PM   #3
frankyjoet
hi b454rat, is it still mechanical with oil sender. i know the hookup for the mechanical oil gauge. this PCB does not support an oil mechanical gauge, it is setup for an electrical wire hookup. thanks
Old 03-03-2013, 10:03 PM   #4
b454rat
So what are you looking then?
Old 03-03-2013, 11:44 PM   #5
frankyjoet
i am looking for a way to solve this problem with the gauge being at 3'oclock. is it a ground issue. when i test the oil sender i'll get back to you.
Old 03-04-2013, 06:16 AM   #6
hatzie
Moderator
hatzie's Avatar
What year is the cluster you're using?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-04-2013, 10:58 AM   #7
frankyjoet
hatzie this cluster is from an 89 gmc, bought on ebay. i know most things work on 73 and on. my problem is the elec oil gauge sits a 3'oclock. it is properly grnd. we are talking about 2 wires on the clustr plug. the gauge uses 3 metal contact clips on the cluster 2 for power 1 for grnd. hookup is the power wire from fuse bx is attd to 1 wire, the other to the sender wire. i could take a pic of the cluster if needed. hope this helps.
Old 03-04-2013, 04:26 PM   #8
frankyjoet
Unhappy Re: electric oil gauge 73gmc
here are the pics of the cluster. notice the pink wire #6 is attchd to the blue/blk sender wire. the pink wire the gauge power wire is attchd to beige/white wire #5. there is also pics of the front of the gauges and the back of PCB gauge clips. hope this helps. i cannot upload pics?
Old 03-04-2013, 06:21 PM   #9
frankyjoet
hatzie ,the problem is solved, i found a bad oil pressure sw, put a new one and hooked the wires and the needle wento 0 on the oil sw. thanks for the help.
