cam going to provide enough vacuum for brakes?
So bear with me if this is a silly question. I'm building a .030 over 6.0L. Cam specs are 223/230 .634/.608 114+4 will this cam make enough vacuum for my brake booster or do I need to look at hydroboost?
Posted via Mobile Device |
meowMEOWmeowMEOW
Re: cam going to provide enough vacuum for brakes?
You have a high enough LSA that the brakes should work pretty much fine; you can always add a small vacuum resevoir if its something your really worried about, but it shouldn't be necessary.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Feb 2009
Hydroboost?
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() |
meowMEOWmeowMEOW
Hydraulic assist braking system that runs off a different power steering pump and booster. Can lockup just about any set of brakes you can find.
![]() I'll go back to my corner of the room now... ![]()
