Old 03-03-2013, 09:44 PM   #1
1967gm4x4
tilt wheel
I have a 1985 high sierra and the other day it seemed like it happened out of nowhere. where it tilts became very loose and you can move it back and forth and side to side a lot more than usual, I wanted to see if anybidy knows what this is before I take it apart.
1967 gmc 4x4 factory air factory buckets
1985 gmc high sierra 2500 4x4 400 1972 ford f250 4x4 390.Tomorrow is the most important thing in life. Comes into us very clean. It's perfect when it arrives and puts itself in our hands. It hopes we've learned something from yesterday. John Wayne
1967gm4x4 is offline   Reply With Quote
Old 03-03-2013, 09:48 PM   #2
notallthere
Re: tilt wheel
There are four bolts down inside the tilt mechanism that have come loose. Not a bad job to do just take your time and keep organized.
notallthere is offline   Reply With Quote
Old 03-03-2013, 09:54 PM   #3
1967gm4x4
Re: tilt wheel
What do you have to take off to get to them?
Old 03-03-2013, 10:53 PM   #4
notallthere
Re: tilt wheel
This is one of the best videos I have seen to do the job. If I can find it I downloaded and printed a manual a couple years ago to do it.
Lisle makes all of the specialty tools to do the job as well. I found O'reilly auto parts had all of them when I needed to do it the first time.
Old 03-05-2013, 07:22 PM   #5
1967gm4x4
Re: tilt wheel
Thank you that video is very informative hopefully ill get time to tackle it this weekend.
Old 03-05-2013, 08:14 PM   #6
DetroitIron
DetroitIron's Avatar
Re: tilt wheel
I did this last year and really love the results...best advice is plan a whole day and go slow with organization...I was a bit taken back by how far down in the 4 bolts are in the column. Good luck
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 03-05-2013, 09:49 PM   #7
Damon23
Damon23's Avatar
Re: tilt wheel
Wow, what a job. I have a turn signal and ignition switch going bad in mine. You can actually turn the tumbler by just putting in the key. I'll just buy a new column, need a tilt anyway.
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
