Old 03-05-2013, 12:05 AM   #1
manimal
manimal's Avatar
small block in a crewcab dually?
Anybody have a 350/383/400 in a crewcab dually 2wd? If so, how does it do pulling the truck around?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 03-05-2013, 12:51 AM   #2
Ziegelsteinfaust
Re: small block in a crewcab dually?
My friend had 77 with all the bolt-ons, and T700R4. I thought it was just fine for driving. You could feel it was a bit strained with a full load of people, but no big deal. It was you felt the weight faster then you'd ever feel on a 454.
He wanted a CC dually to drive around, and tweaked it for mpg. For what he absolutely had to had he was very happy with it. The big problem was the 350 took a hammering from the heavy truck where the 454 would of lasted longer.
Also my feeling is that a 454 is better suited that with the same bolt-ons, T700R4, and quality of tune. Would likely get effectively the same mpg as a 350, but that presumes you geared each engine for optimal driving rpm.
Ziegelsteinfaust is offline   Reply With Quote
Old 03-05-2013, 01:15 AM   #3
spencer_41188
spencer_41188's Avatar
well it dose verry well i have a 383/nv4500/14bff with a locker 4.10 gears and i can do donuts on dry pavement yes all 4 rear wheels because its a cab and chassis axle
one thing to worry about is the fuel tanks!!! im in the prosses of installing a fuel cell because the factry tanks are so long and the pick up being in the center it tends it starves for fuel when you hit the skinny peddel
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 03-05-2013, 08:38 AM   #4
BigBlocksRule
It'll pull the truck around fine, but don't count on doing much towing.
BigBlocksRule is offline   Reply With Quote
Old 03-06-2013, 12:32 PM   #5
Desert1957
Desert1957's Avatar
Couldn't be more wrong....
Here is my 350 crate motored small block pulling all this , does just fine.
(SM 465 and 4:10 rear)
Desert
Desert1957 is offline   Reply With Quote
Old 03-06-2013, 01:07 PM   #6
Keith Seymore
Keith Seymore's Avatar
Fuel economy numbers?
Is that a towing dolly I see between the truck and the trailer?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-07-2013, 12:28 PM   #7
Desert1957
Desert1957's Avatar
K
Keith,
Yes it is, very good eye spotting it. Its a "Trailer Toad" keeps all tongue weight off the tow vehicle.Here is a better pic.
Gas mileage is bad, about 8-10, but a square tow rig with a new crate motor is why I personally like it.
Desert
Old 03-07-2013, 04:22 PM   #8
comegetsome2003
comegetsome2003's Avatar
If you want to tow and get good mpg then just do a 12 valve swap and never look back....happy with mine and it knocks down 20+ mpg all day long
1991 Square CCLB Dually...laid out on 22s with an old noisy 12 valve
comegetsome2003 is offline   Reply With Quote
Old 03-07-2013, 04:59 PM   #9
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
I have 350"/345 hp works fine.
But it's hard to beet (pun intended) a big block for hard work
johnnyclack is offline   Reply With Quote
Old 03-05-2013, 10:12 AM   #10
manimal
manimal's Avatar
Thats kinda what I thought. I have a Big Block, I might as well use it. Thanks!
-Lance
Old 03-05-2013, 10:26 AM   #11
BigBlocksRule
If you really want to make it worth doing, add a 4L80E and TBI at the same time. You'll get reliability and better fuel economy. Harnesses are cheap, run it with a factory computer with tune. I've found a few 4L80E cores that came out of trucks that had never towed, changed fluid and filter and dropped 'em in with no issues. If you're going to do that, research the truck it's coming out of, I wouldn't use one as-is if it had been beat on. Expect to pay $250 - $400 for a good one, sell the old TH400 for $200 - $250. New harnesses are $300, just need to figure out the speedo and you're good to go. My current project hauler is an '85, I found a set of '92 gauges with electronic speedo, might be able to do something like that.
Hell, if it's worth doing, it's worth overdoing!
Old 03-05-2013, 01:50 PM   #12
manimal
manimal's Avatar
I've got a harness already from a '91 diesel w/4L80e..but no controller. Not sure if I want to go that route or not for the expense. I may just sell the harness and stick a GV on the back.
-Lance
Old 03-05-2013, 01:53 PM   #13
BigBlocksRule
It's waaay cheaper to run a factory harness than with a GV, engine and tranny control in one. Lots of folks would like to have your harness to run a 4L80E by itself...
Old 03-05-2013, 06:12 PM   #14
rs72z
rs72z's Avatar
5.3 & 4L60E in mine does great. 18 mpg on some short trips. I havent pulled anything with it.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 03-06-2013, 12:52 AM   #15
bilfman
bilfman's Avatar
I just did a 4l80e swap this year. Used a tci controller $600, was a very easy kit to work with, here is a link to the build.
http://67-72chevytrucks.com/vboard/s...d.php?t=537481
As for sbc powered crew, my buddy has a 1988 with a 350tbi and a 4 speed, rolling 4.10 gears. Drive train is full stock, other then a 3" pipe no muffler, truck pulls itself good and is decent pulling a trailer. It isn't an OMG this thing sucks at all, the setup works fairly well.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 03-06-2013, 01:40 AM   #16
andrewmp6
I depends on how you will use the truck.A daily driver that don't haul much a small block is fine.If your going to haul a lot with it a big block or diesel would be better.
Old 03-06-2013, 09:21 AM   #17
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I have a '85 crew cab with a car hauler bed, 350/4 speed. it pull's it self just fine load'd or unload'd.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 03-06-2013, 09:33 AM   #18
D.FENS
My truck is down with a dead trans (goes fine in reverse but won't do anything in forward gears). Still runs okay but needs a ton of service work.
Been eyeing up a 6.0 swap, like an LQ4, and a 4L80E. Seems like the swaps are cheap enough now that you could do the swap, then sell the stock motor / trans / harness to recoup a lot (or at least some) of the money spent on the swap.
D.FENS is offline   Reply With Quote
Old 03-06-2013, 05:44 PM   #19
MalibuSSwagon
I would do it. GM uses them in the 3/4 ton and 1-ton trucks, I think a square body crew cab would be even better application of a 6.0L drivetrain due to the weight advantage. It likely would get double the fuel mileage over a 454 as well.
MalibuSSwagon is offline   Reply With Quote
Old 03-06-2013, 08:24 PM   #20
jimbonice
jimbonice's Avatar
As someone who's owned carbed and injected 454's and 460's, V-10 Ford's and Dodges, 5.7 hemi's all in one ton trucks, I'll dispute that fuel injection will get the big gains in economy that people believe. It's incremental at best. A good carbed engine in a 7000 lb truck will do as well as FI and a big motor will do as well as a small motor. 35 years of hauling crap around had proven it for me.
jimbonice is offline   Reply With Quote
Old 03-06-2013, 08:47 PM   #21
D.FENS
Not likely, the truck got 8 - 10mpg before the trans started trying to lay down. I would be happy with something around 15 on the highway.
Originally Posted by jimbonice View Post
I'll dispute that girl injection will get the big gains in economy that people believe. It's incremental at best.
First off, does this thread really need that?
Second, LS swaps are fairly often working out to be cheaper than rebuilding a SBC, never mind a 7.4. My truck is already TBi, so the mileage is pretty close to as good as it gets with that combo.
I could spend two stacks doing a bargain basement rebuild on the 454, then another couple on what little aftermarket parts are still available for a 7.4 TBi, then maybe another grand on a 4L80E / Suburban harness to run it. That would probably net me a mileage improvement of maybe 1mpg. Great return for the investment.
Or I could swap it for maybe 3 - 4K, have more HP and torque, and it's mostly factory parts. And have a good running BBC to sell when I'm done.
Old 03-06-2013, 08:52 PM   #22
jimbonice
jimbonice's Avatar
Chill Bill, thats fuel, not girl
Old 03-06-2013, 09:02 PM   #23
68Timber
I know the pieces fit
68Timber's Avatar
They make good power and rev well, I'd rather have a small block truck or diesel. Nothing wrong with a good big block except the mileage. I'd swap in an LS motor first.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-06-2013, 09:10 PM   #24
SSC's76
No No
SSC's76's Avatar
with the right gears you would not know the difference between the 2 unless you were to pop the hood. If a 350 is good enough for a suburban its fine for a qcd.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 03-06-2013, 11:17 PM   #25
meatwagon83
meatwagon83's Avatar
i actually have a lq4/4l80 swap and after talking to a LOT of people with 6 liters in thier duallys i have found that empty they dont get any more than 12-14 mpg, after hearing this several times i concluded that i could rebuild my 454, use the 4l80e and get the same milage while spending less on the swap and get more power out of the 454, sorry this is kinda off topic but these guys keep talking about overdrives and swap so i thought i would throw it out there, btw there isnt anything wrong with a smallie in a dually as long as its geared correctly, although they lack the torque of a big block
meatwagon83 is offline   Reply With Quote
