Old 03-06-2013, 09:19 AM   #1
focusedontheprize
focusedontheprize's Avatar
Problems with timing on my 292
Picked up the complete motor out of a 1970 Chevy C10 farm truck. I went through the motor, cleaned it, painted it, and put everything back together.
The timing on the motor is suppose to be 4 degree BTDC. So last weekend I went to time the motor (I have the timing light with the adjustable dial on it) and once it was warm I was noticing there was no way I could get to 4 BTDC without the motor dying.
I have moved the teeth on the distributor forward and backward thinking maybe I was off a tooth. No matter what I do, the truck runs fine when it is timed at 20 Advance.
Before I start ripping this front end apart to see what it is I have a few questions for you gurus:
1). If I am not off on the distributor teeth, what would be the next thing to check?
2). I am sure I aligned the timing gears correctly, but I will have to doubt check that.
3) Is it possibly the balancer slipped on the rubber and has moved?
Thanks.
focusedontheprize is offline   Reply With Quote
Old 03-06-2013, 09:24 AM   #2
focusedontheprize
Re: Problems with timing on my 292
Mods -
Apologies, see it is in the wrong forum. Can you move this pls?
