Old 03-06-2013, 10:19 PM   #1
mgchevyparts
mgchevyparts's Avatar
Replacing inner rocker
Just starting to replace innner and outer rocker on my 71. I was eyeballing, from underneath the floor pan to inner rocker area. Noticed that the forward floor brace is spot welded to the inner rocker, right below the front door pillar point. There are 2 or 3 bolt heads at the outer end of the forward floor brace. What are these bolts holding inside the rocker cavity? Are they just connected to the inner rocker, the floor brace is spot welded to the inner rocker why the bolts?
mgchevyparts is offline   Reply With Quote
Old 03-06-2013, 11:57 PM   #2
sduckworth13
sduckworth13's Avatar
Re: Replacing inner rocker
Take a picture and circle the area. If the floor brace? is spot welded to the inner rocker then someone has replaced the cab supports in the past. The bolts going into the inner rocker are for connecting the front and back door pillars.
Scott
sduckworth13 is offline   Reply With Quote
Old 03-06-2013, 11:59 PM   #3
sduckworth13
might want to PM a admin and ask to move this thread to paint and bodywork, you'll get more help on your subject.
Scott
Old 03-07-2013, 12:13 AM   #4
Lattimer
Lattimer's Avatar
The bolts are original. They hold the inner and outer together and should also hold a bracket that reinforces the bottom fender mount.
The welds probably indicate a repair, as mentioned.
When I replaced mine none of the bolt holes lined up, so I said screw it and welded everything.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-07-2013, 12:25 AM   #5
mgchevyparts
Possible that it's not spot welded since it's still in original grease and grime. Since I can't see inside the rocker chamber I wondered why the bolts, so there is a bracket on the inside which I can't see at this point.
Old 03-07-2013, 12:30 AM   #6
Lattimer
Lattimer's Avatar
Yes, bracket should be on the front 2 bolts and bolt to the inside of the front fender with one bolt.
Shawn
Old 03-07-2013, 12:51 AM   #7
mgchevyparts
Old 03-07-2013, 11:34 AM   #8
~Whitey~
~Whitey~'s Avatar
This page of my build thread will show you what's inside the rocker front and back.
http://67-72chevytrucks.com/vboard/s...=555682&page=4
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
