Old 03-07-2013, 12:16 AM   #1
Hardesty454
Hardesty454's Avatar
Big Block Water Pump.
Mine is out and done for....
Went to just get the stock replacement and its about $100!!
Looking through summit, ebay, etc and dont know if I should order the stock OE replacement, a higher flow, or just swap it all over and get an electric pump and fans.
Difference between long and short (Nose cone?)
Benefits to either? Issues with one or the other?
If anyone has a good suggestion on brand as well please feel free to let me know!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 03-07-2013, 12:19 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Big Block Water Pump.
Long and short water pumps are different. You need to know which one you have. What side of the engine is your alternator on? If it is on the drivers side, you have a short water pump. If it is on the passenger side, you have a long water pump.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-07-2013, 12:30 AM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
Had a stock cast iron GM pump, Replaced it with electric and had heating problems with 2 duel electric fans . Replaced with the aluminum Edelbrock high flow belt drive pump and works great, and it looks good too
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-07-2013, 12:32 AM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
To add to leddzeps comment, if you change from short to long or long to short, you also have to change alternator brackets, p/s brackets, and all the pullys which gets pricey. I could be wrong but I think the p/s pump may also be different.
If it were me, I would stay away from electric pumps for a daily driver. $100.00 for a new stock replacement is not bad as they are getting $60.00 to $70.00 for a reman. Reman are ok but after they have been remanufactured a few times the cores get a little beat up and fail more often.
Just some thoughts.
TBONE1964 is offline   Reply With Quote
Old 03-07-2013, 12:34 AM   #5
Hardesty454
I have a short pump.
Edelbrock high flow you say? Which model? Where did you purchase from?
Rob
Old 03-07-2013, 01:56 AM   #6
JellyBeanDriver
I just went through this. Bought a GMB from Amazon. Really nice casting, great price, good feel, all the holes and posts lined up with no issues.
This was after looking at Autozone's $59.99 HD unit, and both offerings they had at O'reilly (new and rebuilt).
I've got a Prime acct so the shipping was free and the unit was $34.99 but I see they're currently out of stock for the one sold by amazon themselves.
Same unit sells for $56 at Summit.
GMB 130-1320 OE Replacement Water Pump :... GMB 130-1320 OE Replacement Water Pump :...
edit: Nevermind - this is for the long pump. Take a look at GMB anyways.
JellyBeanDriver is offline   Reply With Quote
Old 03-07-2013, 02:08 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Spend the $100 and get a quality replacement. It is the most economical and sensible route to take if there are no other problems with your cooling system.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-07-2013, 08:15 AM   #8
MARKDTN
If you have time, take yours and have it rebuilt. I had one done at CarQuest and it was like $40 and I had MY core back. Took about 2 weeks I think.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-07-2013, 10:05 AM   #9
cdowns
cdowns's Avatar
i'd look at the aftermarket cast aluminium water pumps// i have always figured every little bit of weight taht you can save is worth it
Old 03-07-2013, 11:08 AM   #10
kelsfine69
18 Till I Die
kelsfine69's Avatar
I bought mine locally. Natural cast aluminum finish. Heres some links
http://www.jegs.com/photos/300/350/350-wpinside.jpg
http://www.jegs.com/p/Edelbrock/Edel...44307/10002/-1
I see they have other finishes now like black and endurashine. I like the cast look to match my intake. It works well for me
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 03-07-2013, 11:20 AM   #11
Hardesty454
Thanks guys!
Rob
Old 03-08-2013, 01:18 AM   #12
67ctener
67ctener's Avatar
Can a long pump be ran with the stock mechanical fan with clutch and clear the radiator?
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 03-08-2013, 01:24 AM   #13
Hardesty454
No. Won't clear. Besides that you would need all new brackets...
Rob
Old 03-08-2013, 02:29 AM   #14
67ctener
67ctener's Avatar
Wanted to run the bs serpentine
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 03-08-2013, 10:12 AM   #15
cdowns
cdowns's Avatar
i think most serpintine use reverse rotation pumps so determine that first b4 goin any further
Old 03-08-2013, 10:35 AM   #16
70CHEVYBB
70CHEVYBB's Avatar
Cp5038 is orielly's part number for the reverse rotation water pump. less the 50 bucks. Its the same one I am using on my big block with the KWIK Performance adapter plates to use sbc brackets.
70CHEVYBB is offline   Reply With Quote
Old 03-08-2013, 11:37 AM   #17
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Saw a nice marine short pump on Ebay, had straight cut brass impeller so it could run clockwise or counter.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 03-08-2013, 01:34 PM   #18
WIDESIDE72
WIDESIDE72's Avatar
IMO a straight cut impeller wod not pump well
WIDESIDE72 is offline   Reply With Quote
