Old 03-07-2013, 02:37 AM   #1
dwcsr
Hollister Road Co.
dwcsr's Avatar
1949-50 3100
1949-50 3100
I say its a 49-50 because the owner says its a 49 but everything under the cab says 50 up and the windows and door handles say pre 51. Not that it matters but its always nice to know that its not a franken truck when you start the project. This is a customer job so its going to go fairly fast but not monkey fast or Foose fast. I'm doing the chassis, engine and body metal work and the body finishing and paint work go to a painter I do work for. Then it comes back for assembly of the large items, Cab , bed , engine final setup.
This is a truck that has already been resto'd once and was really an on chassis paint job. The body looks good from the outside. I'm hoping that when its apart and blasted it still looks reasonably good. I didn't see a lot of paint blisters from this 8 year old paint so maybe its ok and I'll have to do minimal rust and metal work.
Its all original other than a 12v conversion so all the drive line and brakes are being replace with an S10 cross member weld in and four wheel Disc and a 5.3 connect and cruise package. I went with S10 and off the shelf pieces because its going to be a daily driver and want time and mileage proven parts on it.
So far the specs are:
Front end
Scott Danforth front cross member. Based on GM Metric A-arms and components. (GM Metric include the '78-'88 El Camino, Malibu, Cutlass, Monte Carlo, S-10, Camaro etc. These chassis are also used as the basis for many racing applications, so tubular upper and lower A-arms large brakes, etc. are available) He supplies the weldment you supply the A-arms and components.
Drive line
CPSLC94L65E CONNECT & CRUISE - LC9 5.3L & 4L65E PACKAGE
it's a stock 5.3 crate with the trans and controller and PCM with harness.
12 bolt 3:23 w/ disc kit . Spring suspension. No bags or air.
Boxed frame
AC unit
Under bed gas tank. TBD
I'll post pictures as I have them. Saturday I get it delivered to my shop and will take some "as is" pictures
Old 03-09-2013, 04:11 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Had the truck picked up today so here are some of the pictures as it is now
Old 03-09-2013, 04:18 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Inside the cab and side of truck. As it goes along I'll show what we found and how we fixed it. Looking at it closer today I see a lot of filler in places that should have been metal.
Monday we start disassembly tagging and bagging as we go. The trim looks good enough to get re-chromed. We'll see what we find on Monday after its get taken apart. The goal this week is taken apart survey what needs fixing and replacing then get it off to the blaster.
Old 03-10-2013, 11:51 AM   #4
wood1
Re: 1949-50 3100
Looks pretty good in pictures, I'll be watching your progress. It does look to be '49 or '50 as you say.
And a nice Fulton visor!!
Why did they flip/flop the speedometer & gauge cluster??? (speedo should be on right side)
Thanks, look forward to more pics of build.
wood1 is offline   Reply With Quote
Old 03-10-2013, 12:52 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
The truck looks good from 50 ft. but up close you see a lot of sanding waves and spots where bondo was gobbed on. It looks like the corners are all bondo.
But in general its in very good condition to start a frame off. When I first saw it I thought it was one of those Old Navy trucks but its much better than that. Sand Blasting will show where all the problems are hiding.
Not sure on the Speedo. I think they just may have forgotten what went where on the last resto. Outside of this board and Stovebolt I don't think any one else would have noticed that. I'm sure there will be more "I wonder they they did that?" questions as time goes on.
Old 03-11-2013, 02:14 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
I just got a price on blasting the truck completely disassembled.
Picked up , blasted, primed and deliver back to me was $1350. I think that's a good price for what their doing and saves me a day in loading and travel.
The blaster is about 40 miles one way from me.
Old 03-12-2013, 07:41 PM   #7
69CST-V
69CST-V's Avatar
Re: 1949-50 3100
I'm in. Looks like you may have enough supplies to fix your roof next time it leaks. LOL
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 03-12-2013, 08:40 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
I think so.....Just need to pull the nails out of the tries and I'm good to go.
Old 03-12-2013, 08:45 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
This was the before and after on this wheel house. We looked under it when we first saw it and it was so well covered up with undercoating it looked ok. but as you can see its anything but ok.
Old 03-15-2013, 05:48 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
It is striped down engine out, cab loose, bed off and apart, ready to go to the blaster. Nothing real crazy under the truck, looked like it was all stock and had a rebuilt 216 in it.
Old 03-18-2013, 03:21 PM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
The owner came to look at the truck today before it goes off to the blaster and he was under the impression that it had been a frame off restoration that he paid 16K for 8 years ago. He was very surprised that the frame looked like it did and all the rot through in the cab. I had to tell him it wasn't a frame off or even a bed off restoration. Not a happy camper....
Old 03-18-2013, 10:48 PM   #12
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
The truck has been picked up by the blaster so we have 7 - 10 days before it comes back. This gives us time to make a cab dolly. The basic design is spec is casters, tilt in at least 2 directions, 4 if its not to difficult or to unstable to do and have it not weight as much as the truck. I have an old frame that I'll use for the cab mount and just have to come up with the tilt part. More details as it fleshes out.
Old 03-21-2013, 06:55 PM   #13
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
We have the Cab Dolly almost completed. I decided to make it lift side ways rather than end to end that way the whole side is within reach at one time.
We made the hinges out of 3/4 black pipe with some removable pins so you can lift one side or the other. The casters are 8" swivels. The saw in the picture is a Milwaukee 14" Dry Saw it cuts very smooth and very quickly leaving nice square ends and very little burr. It cut the 2x4 x.120 like nothing.
We first made the base on casters and then made up the hinges. Simple design and not much in cost.
We have the up right locks to make and paint it up
Here are the pictures
Old 03-22-2013, 05:00 PM   #14
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 1949-50 3100
Man I know he was steaming, but you will get it together for him.
Kabwe is offline   Reply With Quote
Old 03-22-2013, 06:34 PM   #15
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
I appreciate the compliments guys,
xpickup
That saw is great , The only issue is that if you have the blade partway down when you slide metal in the clamp and it hits the blade it will chip the carbide and start knocking teeth off oe chipping them with every cut. I need to get this blade repaired and have a spare. But other than that I don't know how I ever did it with an abrasive blade. Like you say sparks everywhere, dirt flying and stink plus a mediocre cut.
rgunlock
The hinges idea came from when I was a jeweler and we made all our hinges from tube and pin. As long as you have room for a tight pivot they work nicely. Just remember you weld the top of one and the bottom of the other, not the top of each, or the top and bottom of each,,,done that more than once and wondered why the jewelry box wouldn't open. The floor locks I bought online. Foot operated, one for each end. I'll show a picture when I get them in and on.
Kabwe
From what I hear the guy was upset but sees we are really doing a frame off and has seen what has to be done. I'm told he's excited about us doing it for him so that's a good thing.
Old 03-21-2013, 09:13 PM   #16
Denee007
Denee007's Avatar
Re: 1949-50 3100
I see you put your new saw to good use! You are quite the fabricator!
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 03-22-2013, 07:06 AM   #17
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Thanks but that saw will make you look good no matter what your skill level if you know how to use a tape measure.
Old 03-22-2013, 10:38 AM   #18
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Last picture on the Cab Dolly. I decided to use a 3/4 inch black pipe as the up right brace. It locks into the running board bracket and a hole on the lower dolly frame. I may make one for the front as well if it flexes to much with a cab on it. Last item is a pair floor locks so it doesn't roll all over when working on the cab
Old 03-22-2013, 12:27 PM   #19
xpickup
xpickup's Avatar
Re: 1949-50 3100
dwcsr, nice work. I like your cart. When my metal chop saw dies it is getting replaced with one of those dry cut saws. They make nice bur free or hardly a bur and non smelly cuts. And no abrasive dust everywhere.
Shannon
xpickup is offline   Reply With Quote
Old 03-22-2013, 12:30 PM   #20
rgunlock
rgunlock's Avatar
Re: 1949-50 3100
Cool idea on the hinges. Interested to see what you will do for the floor locks. After building mine, I wish I'd used at least 2 casters that have the built in locks because it does roll all over on me. I'll have to swap them out when I get the cab back off the dolly, or come up with a plan "b", or let you figure it out and copy from you
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 03-25-2013, 08:32 PM   #21
Denee007
Denee007's Avatar
Re: 1949-50 3100
Wouldn't you just love to have a sit down conversation with the folks that did all that "fine" work! Kind of like on my truck~ a "reputable shop" did all the paint/body work~ yeah!argh!
Old 03-25-2013, 10:19 PM   #22
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Its sad to know shops like that exist. I'm just glad he saw it prior to blasting and still painted blue he would never have believed it was his truck.
Old 03-27-2013, 09:18 PM   #23
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
It came back late today and its not good. The blaster said he had never seen so much filler on a truck. Almost every panel has a hole in it and the door was filled half way up. What they did was used screen and a patch then poured filler on it sanded it down and sprayed the back side of the panels with bed liner so it looked good on both sides. The fenders front and back, the hood, the left bed panel, around the windows front and back in all the hard to fix spots. The belt line is cheese. I'll take pictures tomorrow and post.
He had to grind off the liner in most spots and left it in places he knew we were cutting out anyway. The total on the blasting came to $1700. If anyone is looking for a blaster in Houston www.affordableblasting.com. They do a very good job, he delivered on time and he has experience with vehicles like ours.
Old 03-29-2013, 06:28 PM   #24
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
Here are some pics of the cab. If you look back you wouldn't think its the same one I sent to him. They bondo'd and back sprayed everything they tried to hide. None of this was visible prior to blasting.
Old 03-29-2013, 06:28 PM   #25
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949-50 3100
More
