Old 03-07-2013, 04:21 PM   #1
hardhead
AC compressor?
I have a LQ4 and I'm about to install AC. I dont have the compressor that was on it but I have the bracket. What are you guys using? Should I just buy one from for the vintage air? It's in a 66, give me your ideas.
hardhead is offline   Reply With Quote
Old 03-07-2013, 11:27 PM   #2
solidaxel
solidaxel's Avatar
Re: AC compressor?
Will the stock compressor fit in your chassis in the lower position?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-08-2013, 02:15 AM   #3
jorgensensc
jorgensensc's Avatar
Re: AC compressor?
This is what I can tell you. I'm doing an ls swap right now. I have vintage air in my '72 burb. Vintage air says a newer compressor won't work, something about them being variable. Others say it will work. I finally spoke with Brent at Dirty Dingo (Great Guy By The Way). He said it won't work well and actually gave me a great and thorough explanation as to why. Something about blowing cold then blowing hot. There is supposedly a newer compressor that is not variable, I think off vans. At the end of the day a new sanden compressor was 199.99 for the serpentine compressor. It cost a little more, but will be a lot less headache. Hope this helps a little!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-08-2013, 08:36 AM   #4
solidaxel
solidaxel's Avatar
Re: AC compressor?
I heard the same story!
My local A/C guy said it would work with my stock 78.......................but there was a bit of interference with the chassis.....so he sold me a "larger" cubic inch Sanded for my DD brackets!
LS 3 4L70E
Old 03-08-2013, 09:10 AM   #5
Clyde65
Clyde65's Avatar
Re: AC compressor?
look at Kwick performance, they have a bracket also.
I have a LSX compressor from 2002 on my OLD AIR Products A/C system and it works just fine, I heard that the variable valving will perform considerably lower on these systems though. You can go with the high mount Sanden with the ribbed pully ( get it when you order your VA system) or if room is sufficient then use the stock LS, get you a compressor from a 1999-2002 and hook it up.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-08-2013, 03:04 PM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: AC compressor?
Here are some mounts if you want to run an aftermarket Sanden down in the original location.
http://www.alangrovecomponents.com/LS.htm
I also like Holley's high mounts. They are cast aluminum like the rest of your accessory brackets and don't look out of place like plate steel or aluminum.
They have brackets for an R4 compressor
http://www.holley.com/20-131.asp
or a Sanden
http://www.holley.com/20-134.asp
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-08-2013, 11:57 PM   #7
hardhead
Re: AC compressor?
I believe it would require some trimming for the stock compressor. I like the looks of the Holley lower mount but I wonder if it would clear the frame with a Sanden compressor. I dont care for the upper mounting location but may have to live with it if its the only one that will fit.
Old 03-09-2013, 01:00 AM   #8
jorgensensc
Re: AC compressor?
I just got all of my mounts from dirty dingo. I ended up doing both the AC and the alt/power steering brackets. It felt unsymmetrical with just the ac bracket alone. I know it was probably a waste of money! I will say the brackets showed up and they look very nice! Hopefully I can get the engine cleaned up and install the brackets this weekend. The other factor I considered was that I already have a sander compressor installed up high on the 402, so the lines will mount right up. Saves a little money trying to remake lines to fit. Also I wasn't in love with the idea of cutting the frame rails, even though I know it's minimal.
Old 03-09-2013, 10:27 AM   #9
Jon01
Jon01's Avatar
Re: AC compressor?
I've run the stock compressor on several swaps and they have all had ice cold a/c.
Now, granted, all of the swaps I've done have been LM7, LS1 and LS2's. I haven't done any 07+ motors so there may be a difference in their compressors.
Jon01 is offline   Reply With Quote
Old 03-09-2013, 09:15 PM   #10
sunk99
sunk99's Avatar
Re: AC compressor?
I talked to a tech guy at VA yesterday and was told that the variable compressors only cone on the corvette, T/A, Cameron type engines. He said the truck,Tahoe etc. were not variable and would work fine.
Scott
sunk99 is offline   Reply With Quote
Old 03-09-2013, 09:53 PM   #11
jorgensensc
Re: AC compressor?
That's great info. Odd since they told me all the new ones were variable, except for the van compressors of some type. Not that I'm doubting you at all. It just seems they can't get their story straight.
Old 03-09-2013, 10:13 PM   #12
sunk99
sunk99's Avatar
Re: AC compressor?
I was concerned since I was planning on using the Tahoe compressor & this was the first time I have saw this topic so just wanted to get their opinion.
Scott
Old 03-09-2013, 10:32 PM   #13
jorgensensc
Re: AC compressor?
Here's an interesting read, which supports your info from vintage air!
http://m.ls1tech.com/forums/showthread.php?t=1017290
Old 03-13-2013, 10:26 PM   #14
cjohnson6772
cjohnson6772's Avatar
Re: AC compressor?
Does anyone know the best place to get a serpentine pulley for a sanden 508? I think this thread convinced me to reuse my sanden instead of the factory LQ compressor. Did they come factory on anything I could rob the pulley from in a junkyard?
cjohnson6772 is offline   Reply With Quote
Old 03-14-2013, 09:50 AM   #15
Clyde65
Clyde65's Avatar
Re: AC compressor?
cjohnson6772, VA has them, then take it to an AC place to install it on your compressor ( unless you can do it)
Clyde65
Rebuild of Clyde
support our troops!
Old 03-14-2013, 09:57 AM   #16
jorgensensc
Re: AC compressor?
Just watch the pricing. A new sanden compressor is 199.00. So if the pulley plus installation will cost you more than that your better off getting new.
Old 03-14-2013, 09:59 AM   #17
cjohnson6772
Re: AC compressor?
I found a video on youtube showing the removal/replacement of the clutch and pulley and it looks straightforward enough. I just find the pulley. I'll check with VA.
Thanks.
