03-07-2013, 10:51 PM | #1 |
87 s10 instrument wiring and electrical help for new guy
I'm doing a front clip/motor swap from a 87 s10 into a 52 chevy. Trying to build a "green-rod" that'll get great mileage and have low emmissions...
Ok, if you're still reading, and have stopped laughing here's the questions. First, is there a diagram that outlines the wiring to the insturment panels? This is my current panel input: I'm planning to hook up an electric Autometer quad gauge. Oil pressue, voltage, fuel and temprature. I got a oil pressure sending unit with the gauge. Here's a pic of the back of the gauge... Second, I would like to do away with the headlight switch and go with simple toggle switches. I have a multimeter, would I check the connector for a constant voltage and then check which wire recieves power when I turn the switch on? The wires coming out of the plug are 2 orange, red, yellow and brown. Is it like a stereo where the yellow is constant and the red is power? I'd assume orange's would be power going to the parking/headlights and the brown would be ground? I appologize for being so clueless. I also posted some similar questions in the s10 forum. Hopefullly there's no rules against that. |
03-07-2013, 11:32 PM | #2 |
78K & 79C Jimmys
Re: 87 s10 instrument wiring and electrical help for new guy
you better check but if it's like the full size
1.black is usally the ground 2.dark blue oil 3.temp is green 4.cluster light is grey 5.fuel tan/brown for the switch the headlight uses a breaker not the same fuse source as the taillights brown is parking lights orange power to tails white grounds to work the dome.... may help
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-08-2013, 02:27 AM | #3 |
A wiring diagram http://www.autozone.com/autozone/rep...00c152801c92c0
