BBC with A/C Radiator brackets
So I have a stock 4 core radiator to go into the 67. I purchased a set of used wider brackets to accomodate this radiator. The original core support had rot underneath the battery tray as most do so I have replaced that. Now as I go to put in the lower mounts it hits the front lip of the core support. So I took them and test fit them in the factory core support. Same thing. Quick fix would be to just notch the lip however since it doesnt fit the after market core support and the original core support just making sure I am not missing something as it would be a shame to notch a brand new piece.
Thanks in advance. |
member #16
![]() Join Date: Dec 1999
Re: BBC with A/C Radiator brackets
I used a crescent wrench and bent the lip a bit.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
![]() Join Date: Jun 2012
My 4 core brackets fit OK. but I had to notch the bottom of my support for the 4 core radiator tanks to fit. just used my angle grinder with a cut-off wheel
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
I am a Referee of life.
I've never heard of one not needing to be notched,unless equiped with a 4 core originally.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
