Old 03-09-2013, 07:06 PM   #1
Daddy Brim
Daddy Brim's Avatar
Overdrive+Gear Ratio=Gas Millage
I have a 67 C20 with 350 engine, turbo 400 trans. It also has a Gear Vendor overdrive, it is mounted were the carrier bearing would be. I had the cover off the rear end ( it is a Dana 60 ) and counted the teeth on the gears, 41/16 so it has 2.56 gears. I'm thinking this is probable a good set up for gas millage. The PO. used the truck to pull a 5th wheel trailer, so I guess it has good pulling power. Is this correct or wrong. This is one area I have no knowledge of.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 03-09-2013, 07:12 PM   #2
Billett
Billett's Avatar
Re: Overdrive+Gear Ratio=Gas Millage
Are you asking whether we think it will get good mileage? Is there some reason you can't drive it on the road? I think that would probably be the best gauge. Most c10 mileage threads on here usually have a consensus of 10-12 normally for sbc's 8-10 for bbc's and 16+ on ls engines. From what I've sifted through it seems that although the trans and gearing does obviously help, the size and lack of aerodynamics on these is what really prevents any really good mileage.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 03-09-2013, 07:31 PM   #3
Daddy Brim
Daddy Brim's Avatar
I do drive the truck almost every day, and my gas millage seems to be what everybody is getting. I think my question is, With the price of gas, Is there anything I can do with this truck to squeeze a few more mpg. I'm trying to educate myself on different rear end gears, and if I should change the gears or just leave it alone.
Old 03-09-2013, 07:25 PM   #4
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
If it truly has 2.56 gears I do not think the Gear vendor overdrive is increasing mileage.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-09-2013, 07:31 PM   #5
cdowns
cdowns's Avatar
i doubt u counted the right gear teeth// rotate that rear and look on the big gear to see numbers stamped in it
Old 03-09-2013, 07:40 PM   #6
Daddy Brim
Daddy Brim's Avatar
I counted the teeth on the big gear 41 then the gear parallel on the right 16. is this correct. I can pull the cover back off and look for a number, but probably not until next weekend.
Old 03-09-2013, 07:35 PM   #7
davischevy
davischevy's Avatar
I agree. The only way to tell is going to be with a fuel mileage run from point A to point B and back, with the OD engaged and without.
Sidenote; My stock 1/2 ton has 3.08 gears, and I don't believe it would pull itself with 2.56 gears, let alone with overdrive.
davischevy is offline   Reply With Quote
Old 03-09-2013, 07:32 PM   #8
67swb72klb
67swb72klb's Avatar
that 2.56 gear does not seem right in a 3/4 ton truck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 03-09-2013, 07:33 PM   #9
Sideways
Sideways's Avatar
Is there a set of numbers stamped on the ring gear?
Sideways is offline   Reply With Quote
Old 03-09-2013, 07:46 PM   #10
Billett
Billett's Avatar
I agree with these guys, 2.56 doesn't seem right. Also, I'd say the only way to get more mpgs out of these is an ls swap. The reason I say that is because I considered swapping to a manual trans with more than my current setup of 3 gears to one with 5 or 6. In the end it would cost me about 6300 miles worth of gas just to do the swap and I'd only end up with maybe 2 more mpg. With an ls you get a great engine, great trans, 10 more mpg, and it only costs about twice as much if you stick with stock parts.
Will
2024 Toyota Sienna
Old 03-09-2013, 07:59 PM   #11
Sideways
Sideways's Avatar
Not the side gear,were the four gears are housed.You want the pinion behind those that the drive shaft yoke is hooked to .
Old 03-09-2013, 08:15 PM   #12
Daddy Brim
Daddy Brim's Avatar
I see I'm wrong with my statement of 2.56 gears. Transmissions and Rearends are one area that I know nothing about, I'm trying to educate my self. I'm going to pull the cover back off were will I find the number that is stamped on there ?
Old 03-09-2013, 08:22 PM   #13
Sideways
Sideways's Avatar
If you look on the large ring gear you will see the numbers,divide the small number into the large number. eg:41/10 =4:10
Old 03-09-2013, 08:33 PM   #14
Daddy Brim
Daddy Brim's Avatar
Thanks I will pull the cover back off, but it will haft to wait until next weekend.
Old 03-09-2013, 08:14 PM   #15
SS Tim
SS Tim's Avatar
My guess is that you are counting the ring gear and the right spider grear from your description. The pinion gear is meshed directly to the ring gear. Probably have 4.57 gears that came in leaf 327/TH applications but there was a 4.10 option as well. Can you post a SPID so we can see what you started with? Either way these gears would be a good choice with an G/V overdrive, giving you a 3.56 or 3.20 final drive ratio. Is your O/D working? Just can't see 2.56 gears working in your truck much less overdriven.
SS Tim is offline   Reply With Quote
Old 03-09-2013, 08:18 PM   #16
Daddy Brim
Daddy Brim's Avatar
Spid pic.
Old 03-09-2013, 08:45 PM   #17
SS Tim
SS Tim's Avatar
Fun, your truck seems to have fleet order numbers for the rear axle, springs and suspension. Originally a four speed truck as well. If you find any codes on the axle especially the tubes I would like to see what you have.
Old 03-09-2013, 10:19 PM   #18
factorystock
factorystock's Avatar
This truck is a 1967 C 20, coil spring rear was the standard set up with HO52. Leafs and Dana's were not a regular options on '67 2WD C 20s. This truck has a special order rear suspension, in other words a GMC rear suspension.
factorystock is offline   Reply With Quote
Old 03-09-2013, 10:35 PM   #19
Daddy Brim
Daddy Brim's Avatar
[QUOTE=SS Tim;5936989]Fun, your truck seems to have fleet order numbers for the rear axle, springs and suspension. Originally a four speed truck as well. If you find any codes on the axle especially the tubes I would like to see what you have.[/QUOT
Where can I find the codes from my spid for the rear axle, springs and suspension.
Old 03-09-2013, 11:36 PM   #20
SS Tim
SS Tim's Avatar
With fleet codes it would be very hard and beyond the documentation I have at the moment. My earlier ratio posts were based on a 68 model and I didn't catch my error until factorystock's post.
As this is not an RPO code option rear end the actual ratio could be anything, but a 4.10 or 4.56 seem the most likely.
Old 03-09-2013, 09:34 PM   #21
Daddy Brim
Daddy Brim's Avatar
This is what I have found so far. I will look for more.
Old 03-09-2013, 09:43 PM   #22
1972RedNeck
1972RedNeck's Avatar
Lets say this. It is is physically impossible to fit 2.56 gears in a Dana 60. Period.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 03-09-2013, 09:54 PM   #23
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Number should be where the yellow circle is here:
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 03-09-2013, 11:00 PM   #24
jocko
jocko's Avatar
if there is no code and callout RPO on the SPID (and there is not one in your case), that means it should have the standard rear end ratio - a 4.10 for C20s I believe. However, with factorystock's comment about this being a gmc rear - hard to say for sure.
Old 03-10-2013, 12:01 AM   #25
piecesparts
Parts and more parts
piecesparts's Avatar
Your original statement had that the truck had a TH-400 tranny in it, with a Gear Vendors OD and a 350 engine. I would have to say that there has been some serious changes made to the truck from what your placard in teh glove box leads one to believe. The truck had a 327 Chevy engine with a 4 SPD tranny. Now go to the picture of the OD unit and look at the crossmember and it shows some elongation work from a torch to make the room for the drive components.
My guess is that since you have the TH-400 and a TH-350, the truck has been modified. The TH-400 is a heavy-duty tranny and it uses more fuel than it's counterpart the TH-350 to do work. That is just a fact of life. The OD unit is either there to help the fuel mileage or to help in pulling heavy loads down the road. Is it a unit that gives you gearing up for economy or gearing down for pulling loads. What are your RPMs at different speeds and is your speedometer accurate? What tire size are you running. With that info, we can figure out what you are doing with the OD unit.
Frank
