Old 03-11-2013, 08:58 PM   #1
tbrown5079
Corvette filter/regulator
Does it make any difference where you mount the filter/regulator on the frame to keep the 58 lb. pressure at the rail? Just pick an easy to get to spot?
tbrown5079 is offline   Reply With Quote
Old 03-11-2013, 10:30 PM   #2
whitels1
whitels1's Avatar
Re: Corvette filter/regulator
It doesn't make much difference although closer to the tank will use less hose for the return.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 03-12-2013, 10:18 AM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
^ This.
I've personally mounted it right next to the engine on my jet-boat, and right at the tank on a G-body. Both worked well.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-12-2013, 10:22 AM   #4
Wasted Income
Boosted Member
Also, I'd stick with a GM /ACDelco filter.
In the past with parts store brands, I've got two of them....TWO of them that have been bad out of the box. Also have a buddy that had the same problem.
Turbo diesel
Old 03-12-2013, 12:04 PM   #5
tbrown5079
Thanks for the advice. Would like to mount it on the crossmember behind the tank and then only have one line to the front, but didn't know if I would lose pressure over the longer distance. I have a Wix filter, but thanks for the info on some bad ones. That would be a quick change if you had problems.
