Backwoods Body
c10 to c30
Hey guys Im fixing to rejoin the 67-72 club. Im going to build a 2wd dually. Ive got a couple questions though. On these trucks were there any differences between a c10 frame and a c30 frame? Also how deep am i going to have to go in the front end to swap from 5 lug to 8? Any help would be greatly ap
preciated. Thanks Posted via Mobile Device |
Designated Grumpy Old Man
![]() Join Date: Oct 2001
Re: c10 to c30
Yes the frames are different. The one tons are taller from top to bottom.
You can put a 3/4 ton front cross member on a 1/2 ton. You did not mention the year of truck. If it is 71 or 72 I believe you can just change the spindles. The 3/4 and 1 tons are the same and you can use 1 ton rotors on 3/4 spindles. Hopefully you are going just for the look of a 1 ton. The 1/2 ton frame will not stand up to the loads of 1 ton. For the rear end is your truck a leaf spring? If so get a rear end out of a late 70's to a early 80's flat bed. The pickup rearends are wider but have the same spring mount locations as 71/72's. Good luck.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
Backwoods Body
Re: c10 to c30
The truck is a 72. So I can just swap over to 3/4 ton spindles? Also it is currently a coil rearend. But thats ok I can do fab work. Im not just goung for looks so I will be addibg some cross bracing and boxibg to the frame if its needed.
Backwoods Body
Re: c10 to c30
Another question. While searching for spindles Ive read tgat c20 spibdles are the same from 71 to 87. Is this true?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: c10 to c30
You will need 3/4 ton lower a-arms to install a set of 3/4 ton spindles.
Then both ball joints will have to be swapped out to match your new spindles. Also the steering linkage is different. Are you using drop spindles? Look at 73-87 c30 drop spindles from Belltech or Western Chassis. Performance Online also sells these. Posted via Mobile Device
Re: c10 to c30
You can swap the complete front assembly from a one ton up into the '90s. That would be the easiest way to go. You can find an HO52 coil rear and bolt that in,then just deal with converting to dual wheels. If you aren't lowering you can use 3/4t rear coils w/air bag inserts to heavy-up the rear suspension. If you are lowering you can use later model front end stuff (for the year you install) and in the rear use bags...or blocks with what I suggested above
Backwoods Body
Re: c10 to c30
Yes I plan on lowering. So I can use c30 arms and drop spindles off a mid 80s? What is a H052?
Re: c10 to c30
Yep,just remove at frame. The HO52 is the Corporate rear found in C/20 & K/20s. The C/30 version is called the HO72. They are essentially the same rear,but with different brakes/wheel bearings. C/30s never came with coil rear,though,and only a single rear HO72 had the same width housing. The HO52 is a direct swap with the 12-bolt.
Backwoods Body
Re: c10 to c30
Thanks guys. Im sure I will have more questions. Also anymore input or ideas are still appreciated.
Backwoods Body
Re: c10 to c30
Well Ive got a 72 454/400. Let the work begin. Wish I knew how to upload pics.
