03-12-2013, 08:41 AM | #1 |
wiring question
Is the factory wiring harness from a complete pull out long enough to reach inside the cab for mounting. I don't really want all of that "stuff" under to hood. I am trying not to spend 1000.00 on a painless harness if I can help it!
03-12-2013, 10:33 AM | #2 |
Boosted Member
Re: wiring question
The factory harness puts the ECM up front on the driver side. As it comes out of the donor truck, there is no way it will reach the cab. If you pull the entire harness apart, you might be able to reroute everything and reach that far...but that is a lot of work.
I personally had my ECM mounted in a nice covered bracket up on the core support. You didn't really notice it unless you were looking for it.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
03-12-2013, 02:42 PM | #3 |
Re: wiring question
i used a factory harness, and unwrapped everything and the items that would not reach were things on the drivers side of the motor, injectors, coil pack, temp sender
those things had to have wire soldered in. was labor intensive though, not fast by any means. maybe my next one would be faster.
My Projects- http://67-72chevytrucks.com/vboard/s...d.php?t=557301 Quest for Hot Rod Power Tour 2013. http://67-72chevytrucks.com/vboard/s...d.php?t=543735 my 85 GMC 2wd to 4wd conversion for the wife. |
03-12-2013, 06:07 PM | #4 |
meowMEOWmeowMEOW
Re: wiring question
This depends on WHICH harness you started with. The VAN harness is longer in every way, by a decent amount, and will let you move things around easier, plus the length makes splicing easier if you need to.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-12-2013, 07:02 PM | #5 |
Re: wiring question
2005 truck harness worked for me..
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
03-12-2013, 07:13 PM | #6 |
Re: wiring question
Thanks for the info, I am a LOOONG way off just trying to do my research now!
03-12-2013, 06:53 PM | #7 |
Re: wiring question
It's not a cheap option, but Painful Wiring has an option for their harnesses to mount inside. Anybody that makes or modifies harnesses should be able to do the same thing.
Posted via Mobile Device |
03-12-2013, 08:42 PM | #8 |
Re: wiring question
Harness from PSI mounts it inside. Not 1000.00 and brand new quality connectors. They build the whole harness from scratch. I've heard it is a real quality piece. I'm waiting on mine to show up. Should be in the next couple of days.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-13-2013, 10:58 AM | #9 |
Re: wiring question
thanks for the PSI link, just what I need it looks like.
Crash, I subscribed to your build looks great! |
03-13-2013, 01:37 PM | #10 |
Re: wiring question
They are great people to work with. They have great reviews all over the net, and was actually recommended to me by Brent at Dirty Dingo. Brent also builds cars for a living too. PSI took extra time to find out some info for me regarding fuel pumps and answered a bunch of questions for me weeks before I ordered. Then they tweaked the design of my harness for me as I needed it. I can't wait to get it and check it out!!
Shawn Posted via Mobile Device
