03-12-2013, 07:32 PM | #1 |
20 mpg or not?
Within the week or so, the wife & I will be starting the engine build for the crew cab project we have going on. Over the weekend, It brought up a interesting debate with a few buddies that I trust and respect for their engine performance knowledge. My Goal with this engine is to get 20 MPG. A couple said it could be done and a couple said it wouldn't happen. Everyone made their points and theories. The debate and conversation was educational and interesting so I thought Id ask it here and see what some of the thoughts are.
The truck is a 88 1 ton crew. 4:11 rear 305/70/16 tires 700r4 trans the engine will be a .30 over 5.7 58cc 187 swirl port heads with a mild port job. 20cc dished pistons vortec Roller Cam 191º/196º 0.414"/.428" lift on a 111º LSA. 1 5/8 headers so do you think it will get 20 MPG? Last edited by mrhino; 03-12-2013 at 08:31 PM. |
03-12-2013, 07:36 PM | #2 |
Re: 20 mpg or not?
Since our vehicles have the aerodynamics of a brick I would be surprised if 20 mpg is possible unless coasting downhills.
Posted via Mobile Device |
03-12-2013, 07:44 PM | #3 |
Re: 20 mpg or not?
I suspect no.
I can get 20-22 ish with my truck, which is a 1/2 ton shortbox with a 4.3, 3.73 gears and overdrive. You've got your work cut out for you, especially with those 4.11 gears. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-12-2013, 07:58 PM | #4 |
The One And Only !!!
Re: 20 mpg or not?
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
03-12-2013, 08:15 PM | #5 |
GoatLube Experss
Re: 20 mpg or not?
Certainly will have to change the gear ratio, the 700R4 will help with a lower ratio perhaps evan lower than 3.73. I'll be curious to see what you do get.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) Last edited by jitteryguy; 03-12-2013 at 08:16 PM. Reason: spell'n |
03-12-2013, 08:30 PM | #6 |
Re: 20 mpg or not?
I always new it would be a tall order. we all need goals right? I Figured I would be at about 1900 rpm at 65 mph
03-15-2013, 02:28 AM | #7 |
Junior Member
Re: 20 mpg or not?
I was about to say, not with that rear end.
I let my 16 year old son drive my every car that I own. I don't let him drive my truck. A man has to draw a line somewhere. |
03-13-2013, 12:46 AM | #8 | |
Parts and more parts
Re: 20 mpg or not?
Where do you drive to get that good of mileage? city/ highway/what speeds/etc...?
Frank |
03-13-2013, 07:51 AM | #9 | |
Re: 20 mpg or not?
K
03-13-2013, 10:32 AM | #10 |
No No
Re: 20 mpg or not?
the engine cam and head combo is capable of doing it but like others have said you need to overcome the weight of the truck. i would suspect you will see 10 and 14 out of that combo in that truck. I would personally choose a more tq oriented camshaft it would provide much better results with your rear gear and trans your working with. anything that makes power from idle to 4500 would be great depending on your cruise rpm if it made max tq 500 + or - in that range thats where you will see the best results
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
03-13-2013, 09:38 PM | #11 | |
Re: 20 mpg or not?
I am looking at your combination and my thoughts are NO, you will not get 20 MPG, you will have to be creative on getting the parasitic loads off of the engine and then it can maximize what you do get. Electric fans will gain mileage, the intake and exhaust setup wiill help in this, get the most spark that you can to the engine, low resistance spark plug wires and a multi-spark setup to get a complete burn of every ounce of fuel in the cylinders. Then look at tires and widths of tires for the best style and lack of rollling resistance for your approach to a mileage gain.
Frank Last edited by piecesparts; 03-13-2013 at 09:45 PM. |
03-12-2013, 07:56 PM | #12 |
Re: 20 mpg or not?
I highly doubt it. Its hard enough to get that with a sbc in a half ton.
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
03-12-2013, 07:56 PM | #13 |
Re: 20 mpg or not?
I work for the worlds largest heavy truck manufacture and we own our own engine company as well. My experience tells me with the current rear axle ratio, the rolling mass of the one ton, and the engine displacement with the specs you listed that 20mpg on a true highway only average is not realistic.
I would suspect if you watch your speed (60mph max) you might achieve a true highway only average of 17 - 18 mpg. |
03-12-2013, 08:13 PM | #14 |
Re: 20 mpg or not?
If you can get that beast to get 20 mpg, you should be an award winning engineer.
The weight, aerodynamics, size of the motor, tires, and wheel base all say no. |
03-12-2013, 09:03 PM | #15 |
Re: 20 mpg or not?
pretty ambitious but like the others here I don't think u would achieve that. you would be better off swapping a 4.8 or 5.3 LS motor. you'll probably get 18mpg + with the LS motor...or switch to diesel.
03-12-2013, 09:10 PM | #16 |
Re: 20 mpg or not?
you're thinking about it all wrong, rid yourself of the old technology. time to find a hybrid Tahoe and get a Harvard grad
03-12-2013, 09:20 PM | #17 |
At the body shop.
Re: 20 mpg or not?
6bt will do 20+
" That didnt make it any newer " " Dont antique the equipment " |
03-12-2013, 10:04 PM | #18 |
Re: 20 mpg or not?
I don't think you get past 17 with those tires. There to wide, and heavy for mpg.
Plus you 14 bolt is a heavy girl at 550 pounds, and you'll need to do the disk conversion for rotational weight reductions. The disk conversion brings your 14 bolt down to a slim 475 pounds roughly. Plus I think a 455 Buick will put down the torque you need for those tires if you need them, and the short stroke you need for mpg. I had a bolt-on "except headers" Electra for a minute with one, and 2.73 gears. It would regularly get 19mpg cruising 70 with the cruise one. I have a spare sitting in my garage from when I got the car, and I am on the fence of putting it in my C20. |
03-13-2013, 10:50 PM | #19 | |
Moderator
Re: 20 mpg or not?
At least 3.73 rather than 4.11 would be the other change to make. The big 455 Buick or 472 Caddy engines are torque monsters and could comfortably cruise at lower RPMs' than a Smallblock.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-12-2013, 10:10 PM | #20 |
Re: 20 mpg or not?
not 20, maybe 16 or 17 if you keep you foot out of it
"DON'T TOUCH THE TRIM!!"-Early Kyler |
03-13-2013, 02:05 AM | #21 |
Re: 20 mpg or not?
Yes, if idling off of a cliff into a mile deep crevasse.
Otherwise, no.
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
03-13-2013, 02:46 AM | #22 |
Re: 20 mpg or not?
With a Gearvendor added to that 700R4 you might get close, but realistically I dont see it. Heavy truck plus its lifted, thats a plow in the wind. No aerodynamics.
03-13-2013, 06:17 AM | #23 |
Re: 20 mpg or not?
My 87 R10 gets 23mpg mixed, would get 26+ at 55 on the highway. But I'm running a 6.2 diesel, no turbo. SLOW.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
03-13-2013, 07:02 AM | #24 |
Re: 20 mpg or not?
For reference, the best I got out of a V8 was 18.5 highway on a 2010 4.8 GMC extended cab with 3.23 gear. On a 2010 V6 LWB Silveado I got 20 city/24 highway, but very little power. For gas mileage I think you should consider an economy car, and drive the truck sparingly.
03-13-2013, 12:38 PM | #25 |
Re: 20 mpg or not?
I was averaging 16mpg out of my k5. I went from an average of 10-12 stock with 273's and 32's to a 4" lift a 44hd and a 14ff with 410's on 35's. it was just a mild tbi 350 with a low end cam, intake, high flow cat with dual 2 1/2" straight pipes off it.
I don't see 20, but I'd imagine around 15 possible out of it Posted via Mobile Device
98 K1500 ecsb 84 C10- 350/350- first vehicle still have 30 some latter 82 C10- 6.2l diesel 700r4 |
