Old 03-13-2013, 05:36 PM   #1
383Blazer
383Blazer's Avatar
Slightly loose hub
So my problem is as stated in the title. I noticed today that one bolt is missing on my drivers side locking hub. This is giving it a little bit of play. I haven't dealt with fixing manual locking hubs in the past so I could use a few pointers as to what to do. Could putting a bolt in the missing spot fix it?
Thanks in advance.
383Blazer is offline   Reply With Quote
Old 03-13-2013, 08:01 PM   #2
Rubble
Re: Slightly loose hub
Are you talking about the Allen head bolts that hold the hub cover on? If so,maybe try tightening the rest up.They might have just worked themselves loose.While you at it,jack up that wheel and check for excess play in your bearings too,this doesn't sound like the problem but it dont hurt to check it.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 03-13-2013, 08:23 PM   #3
383Blazer
383Blazer's Avatar
Yeah I was talking about the Allen head bolts. I tried to tighten them and I couldn't. I will jack up the wheel and check if it is loose too.
Old 03-13-2013, 09:12 PM   #4
1969K10
1969K10's Avatar
lock the hub in, and take all the bolts out to remove it and see what's going on. nothing will come flying out at you.
check the threads in the bolt holes, and see what's going on.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 03-13-2013, 10:34 PM   #5
Rubble
Ya,I am with 1969K10. If your bolts are tight,better pull that cap off and see what's going on inside.Good luck
