Old 03-14-2013, 10:37 AM   #1
BurlyCrew
C-20 & C-10 Frames???
I have a 69 C-20, now does anyone know if the Frames are the same as the C-10 Frames and just the Suspension is different, or are they completely different Frames?
Thanks!
BurlyCrew is offline   Reply With Quote
Old 03-14-2013, 01:25 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: C-20 & C-10 Frames???
They are basically the same if you are talking about ones with trailing arms. I think that the 3/4 ton frames are a little heavier gauge, have extra bracing at the trailing arm cross member and the trailing arms have plates welded on them.
Also the rear cab mounts are lower on the frame to allow thicker rear cab mounts to give a smoother ride in the cab.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-14-2013, 01:51 PM   #3
SS Tim
SS Tim's Avatar
C Blazer
C10 115
C10 127 6.04" height 2.53" flange width 0.156" thick 2.98 section modulus
C20 127 6.11" height 2.46" flange width 0.194" thick 3.71 section modulus
SS Tim is offline   Reply With Quote
Old 03-14-2013, 05:46 PM   #4
BurlyCrew
Originally Posted by SS Tim View Post
C Blazer
C10 115
My main concern was how tall/wide the frame is, but it doesn't look like its very much...
Old 03-14-2013, 07:41 PM   #5
SS Tim
SS Tim's Avatar
To what end are you building?
Old 03-14-2013, 09:18 PM   #6
BurlyCrew
A body dropped truck that lays frame/body on air suspension, with all new dropmember, just didnt know if the frames were the same in all aspects or not
Old 03-14-2013, 09:27 PM   #7
SS Tim
SS Tim's Avatar
Understand, that is a direction I can't help you with. But if I were cutting down a frame a C20 frame is going to be a lot stiffer (~23%) and would seem better able to withstand local loads it was never designed for.
Old 03-14-2013, 09:29 PM   #8
BurlyCrew
Yes plan on cutting it down and doing a shortbed, is the frame tallee?
Old 03-14-2013, 11:05 PM   #9
BurlyCrew
Taller I meant?
Old 03-14-2013, 11:12 PM   #10
SS Tim
SS Tim's Avatar
The GM published numbers are up above. Yes the frame is a little taller, about 0.070". The big improvement is that it is just over 25% thicker 0.194" vs 0.156".
Old 03-15-2013, 12:00 AM   #11
BurlyCrew
Thanks for the info
