Old 03-14-2013, 09:36 PM   #1
duckman777
rear disc conversion
so can i get some thoughts on rear disc brake conversion kits??? I have a 72 SWB and I'm throwing around the idea of rear disc brakes. Is it worth the money? and who has the best kit for the job and cash??
duckman777 is offline   Reply With Quote
Old 03-14-2013, 09:46 PM   #2
Gmcfolife
Gmcfolife's Avatar
Re: rear disc conversion
I've priced around and this company is one of the cheapest I've seen.
http://www.blackbirdscustomtrucks.com/index.html
Gmcfolife is offline   Reply With Quote
Old 03-14-2013, 11:52 PM   #3
HotRod C/10
HotRod C/10's Avatar
Cant beat this kit. I run it and its very nicely built.
http://www.ebay.com/itm/1963-1972-C1...item35bf742f3e
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-15-2013, 10:40 AM   #4
leddzepp
Moderator
leddzepp's Avatar
This is the way to go. No guesswork on the ebrake.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-25-2013, 02:26 PM   #5
BugzC10
BugzC10's Avatar
HotRod,
Did you change your proportioning valve when you installed this rear kit?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-15-2013, 01:09 AM   #6
wibilly
wibilly's Avatar
i build my own using 4wd front caliper mounts and welding them on for 6 lug and 8 lug apps i use the same mounts and calipers on 5 luggers and awd astro van roters for 5 luggers, for these i turn a spacer to center roter on axel rather than relying on the wheel studs to do so i use 76 eldorodo rear calipers for mechanical parking brake. first 1 i did i bought caliper brackets but i dont think they support the calipers as well as the dana 44 ones
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-15-2013, 09:01 AM   #7
Fldawg
Fldawg's Avatar
i pieced my own together for $225 , that's using new parts, but i don't have a e-brake on mine, if your interested i'll put my parts list on here later
Fldawg is offline   Reply With Quote
Old 03-15-2013, 09:15 AM   #8
JointTech
JointTech's Avatar
id like to see the parts list.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 03-15-2013, 10:37 AM   #9
UP GRADE
one set closer
UP GRADE's Avatar
I'll like to see the parts list too.
UP GRADE is offline   Reply With Quote
Old 03-15-2013, 10:39 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Check in the Vendors Marketplace. Capt Fab has a very well designed kit that he sells.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-15-2013, 05:25 PM   #11
JointTech
JointTech's Avatar
i replied in capnfabs thread about if he does kits and/or 8lug stuff.
i sent an email to the blackbird guy becasue i dont know which kit i should be looking at. he told me to take some pics and hell let me know. quick response which is cool. but now ive seen those wilwood setups and im drooling. I just like the idea of a kit becasue i dont really know what i should be looking for.
72 C20 Long Bed
Old 03-25-2013, 08:06 AM   #12
duckman777
Thanks guys I will do some browsing to check them all out. I appreciate all the help
Old 03-25-2013, 09:57 PM   #13
HotRod C/10
I have a Disc/Disc pproportioning valve.......you could stick an inline valve in it too to adjust the pressure.
LS SWAPPED
-1976 SILVERADO
