fuel sending unit
i put a motor and trans from a 85 into my 71. i switched it from a 3speed manual to a automatic. do ineed to get a new sending unit? cause for some reason she aint getting no fuel
Re: fuel sending unit
What size fuel line do you have? If it is not 3/8" then you will want to change out the fuel line and the sending unit.
If it is a 3/8" line then make sure that it is not plugged up. You can also pull the sending unit to check out the pickup screen to make sure it is not plugged. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
1969 Custom 30 wrecker
Any chance you damaged the fuel line during the swap? It runs down the bottom of the floor near back of trans. If no fuel at all now but good before it might be your problem.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
the rubber line that goes from where the steel line ends by motor mounts says 5/16. i think it is plugged though. im gonna blow lines out and pull sending unit and check that out. i might as well pull fuel line off carb and check it too. i dont think lines got damaged during swap but ill put it on the lift and check all of it.
