Old 03-16-2013, 03:31 PM   #1
nickbwilson
91 suburban cluster
hey guys i found a 91 electronic gauge cluster for my ls swap what do i need to do make it work with my swap ifound a article about re pinning the cluster but no diagram any help would be greatly appreciated and in case it matters i will be usin a psi harness
nickbwilson is offline   Reply With Quote
Old 03-16-2013, 11:39 PM   #2
77dwh
Re: 91 suburban cluster
I just did the same thing on my 77 that I did a 5.3 swap into. I repinned it of to make it match and work. I added the signal wire from the pcm to make the speedo work and supplied the ground for the facory check engine light to work. I used the temp sender from a 98 ls camaro to run the gauge and supply the pcm its needed signal. My truck had the mechanical oil pressure gauge so I had run a new wire to the sender make it work. I used the oil pressure sender adapter from autometer and a sender for an 81 chevy truck. It took some work to figure out the details and a few hours of wiring but worth it in the end because other than the aldl you have no idea from the inside truck whats under the hood. Hope that helps
77dwh is offline   Reply With Quote
