Old 03-17-2013, 10:11 PM   #1
Malamute
Malamute's Avatar
Setting Air Ride presets
I cannot get the presets to set when following the instructions. #1 will let the air out of all bags but I want #2 to automatically air to ride height with the ignition and when I follow the instructions I can't get it to save. Does anyone have any tips?
This is the control. Thanks.
Malamute is offline   Reply With Quote
Old 03-17-2013, 10:27 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Setting Air Ride presets
Call or talk to Ridetech.
My E2 presets don't function properly in my blazer either.
I just manually adjust my blazer.
That's why my next bagged truck will have Accuair.
Keith
Convert to disc brakes.
Old 03-17-2013, 11:05 PM   #3
Malamute
Malamute's Avatar
Thanks, I'll try Ridetech's forum or give them a call.
Old 03-17-2013, 11:59 PM   #4
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I have an e3 set up and it works fine. I set it by manually setting each corner to the ride height I want, then press and hold the "2" button for a few seconds until the display indicates it's set. I doubt it's changed much from e2 to e3.
Zoomin is offline   Reply With Quote
Old 03-18-2013, 12:38 AM   #5
Malamute
Malamute's Avatar
That's what I've done and no worky. It says the Ridetech button needs to be held until all the lights are lit first and that's the way I've done it. I'll try it again and then contact Ridetech if it still isn't preset.
Does yours go to the #2 setting when the ignition is turned on? That's what I'm really hoping for.
Old 03-18-2013, 08:06 AM   #6
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I don't have mine set to do that but it is one of the settings in the setup menu. The compressor will come on at startup if necessary, but that's it for me. I'd rather control what it does myself.
Old 03-22-2013, 06:39 PM   #7
Zoomin
Man of Mini-Talents
Zoomin's Avatar
What did you find out?
Old 03-23-2013, 01:01 AM   #8
Malamute
Malamute's Avatar
I had the week from hell at work.....found out nothing. Hit the bar with some friends today to watch hoops and get my mind off of things for a bit. I'll give it a try tomorrow hopefully.
