03-18-2013, 04:09 PM | #1 |
How do you remove the seatbelt retractor plastic shield, so the unit can be removed?
I need to remove the lap belt retractor end to do some cleaning and painting, but I can't figure out how to slide the plastic sheath up so that I can gain access to the bolt that's holding the belt to the floorboard. Any ideas?
Posted via Mobile Device |
03-18-2013, 04:15 PM | #2 |
Moderator
Re: How do you remove the seatbelt retractor plastic shield, so the unit can be remov
Pull it up, that's all there is to it. Might have to move it back and forth a bit.
Here is how to remove the plastic cover on the buckle: http://67-72chevytrucks.com/vboard/s...d.php?t=465715
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-18-2013, 04:27 PM | #3 | |
03-18-2013, 04:42 PM | #4 |
It really is just as simple as giving it a good tug. Then underneath there is only one bolt that holds it all down.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
03-18-2013, 05:03 PM | #5 |
pull harder
03-18-2013, 06:21 PM | #6 |
If you use a heat gun or hair dryer and warm up the plastic it becomes very easy to remove the sleeves.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
03-18-2013, 07:08 PM | #7 | |
03-18-2013, 08:19 PM | #8 | |
The Older Generation
Yes, you are lucky you didn't crack them. I always use my heat gun. It doesn't take much heat but it makes a lot of difference in ease of removal... LockDoc
