03-19-2013, 12:00 PM | #1 |
Hub Centric Rings
So I need a little education - looking to do some smoothies on my 64 stepside.... so I guess I need Hub Centric Rings - I've never dealt with these - has anyone used these - and does any have insight into how you measure for these... completely outside my comfort zone here. Thanks
64 Step Side - The Mistress |
03-19-2013, 03:03 PM | #2 |
Re: Hub Centric Rings
hub centric rings help to center the wheels on the hubs. what type of smoothies are you going with ? Chances are you can get by with out the rings.But if you develop a vibration you can use an E.T. style lug nut.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
03-19-2013, 03:44 PM | #3 |
looking to run some centerline smoothies - I love the look of these
http://www.jegs.com/i/Centerline-Whe...56656/10002/-1 and I can't stand trying to keep chrome on wheels looking nice and figure these are a quick clean
03-19-2013, 03:59 PM | #4 |
Nice lookin' wheels. Too bad the hub is too small!!
03-19-2013, 04:20 PM | #5 |
wouldn't something like this work though -
http://www.jegs.com/i/Centerline+Whe...56655/10002/-1 a bunch of guys run these on our trucks... right?
03-19-2013, 05:05 PM | #6 |
Yes those will work. THe other ones in your other link didn't.
03-19-2013, 08:26 PM | #7 |
not being hub centric on a hub-centric truck with a lug-centric wheel is ok if the hub opening is too large (C/K20 guys do it often by using Ford 3/4 ton wheels on our 3/4 ton trucks). But a too small hub opening is a no-go.
03-20-2013, 09:30 AM | #8 | |
03-20-2013, 11:28 PM | #9 |
if its 5 lug its a 3 in bore , if its a factory drums its 3.5 , the larger bore center ones
will work but the caps are horriable , i suggest machining the hubs down to 3 and run the 88-98 3 in bore wheels caps is way better Posted via Mobile Device
///Relaxed Atmosphere |
03-21-2013, 02:28 PM | #10 |
or just some special hub cabs for for the center like on the Nacho truck right?
03-21-2013, 05:32 PM | #11 |
yes sir , drill and tap the wheels to use early clips and use what ever cap u want , i like the 55-56 chevy truck cap myself
