View Poll Results: How should a np205 be supported behind a manual transmission? | |||
factory - side cushioned mount | 8 | 47.06% | |
No extra support - hangs from adaptor | 8 | 47.06% | |
Mounted solid - angle iron to frame or additional crossmember | 0 | 0% | |
After market - cushioned to frame or additional crossmember | 1 | 5.88% | |
Voters: 17. You may not vote on this poll |
03-19-2013, 04:15 PM | #1 |
Np205 supporting opinions - manual transmission
It seems there are for main opinions when it comes to supporting a Np205 behind a manual transmission. What is the best way to not break the adaptor?
Please fill out the poll. 1. factory - cushioned side mount. 2. No support - hangs from transmission adaptor. 3. Mounted rigid to frame or aftermarket crossmember. 4. Aftermarket cushioned mount to frame or aftermarket crossmember. I have a 67 k20 with a sm465 / np205. My adaptor was broken when I got it and had no support. I do not want it to break again. Posted via Mobile Device
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
03-19-2013, 04:51 PM | #2 |
Re: Np205 supporting opinions - manual transmission
#1,just get it back how it was made.
03-19-2013, 06:08 PM | #3 |
Windy Corner of a Dirty Street
Here we go with this topic again...
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
03-20-2013, 04:49 PM | #4 |
Haha, true.
All I can say is that if you want to rigidly mount/constrain the powertrain to the frame, then make sure the frame doesn't bend or twist.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! Last edited by argonaut; 03-29-2013 at 01:02 AM. |
03-20-2013, 05:31 PM | #5 |
Deleted.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! Last edited by argonaut; 03-20-2013 at 05:32 PM. Reason: Double post. |
03-22-2013, 08:15 PM | #6 |
Thank you for your replies.
Do peoples opinions vary with their use, ie, on road versus off road? What types of factory mounts existed and in what years. Did square bodies come without a side mount? Was their a torsion bar mount in newer models that went up to the engine mount from the side of the transfer case? Posted via Mobile Device |
03-22-2013, 09:18 PM | #7 |
HHHmmm it's missing on mine,it was like that when I got it..guess I'll run it like that to see what happens.but will be a while b4 on road....
1964 BBC 402 4x4 |
03-23-2013, 09:12 AM | #8 |
My old 76 Blazer had 2 bolts on the bottom of the adapter to the crossmember. No other bracing. Never broke the mount or adapter. Truck had a 400+ HP sb400 hooked to a 4spd. Bent the frame at the front from torque and tore up axles/driveshafts. No transfer case issues. Even bent the floor board with the shifter from the engine torqueing over!.
03-23-2013, 04:27 PM | #9 |
About half way down this page there are two pictures of a mount that goes up to the engine mount. Does this style work well? What did they come on? How did they mount to the engine mount?
http://www.greatlakes4x4.com/showthread.php?t=185605 Posted via Mobile Device |
03-24-2013, 12:26 PM | #10 |
those go up to a bellhousing bolt. ive seen them on my square bodies mostly the aluminum tcase years. . you gotta make sure your tcase has the holes drilled and tapped on the sides. it helps from bottoming out the driveshaft and breaking the tcase off. they rarely seem to make it back on ive noticed.
