Another 4X4 Front Sway Bar
EDIT: I HAVE 1 AVAILABLE AS OF 1-23-15 These sway bars are a great improvement to the handling of your 67-72 4wd truck, blazer, suburban. You will need to remove your front crossmember and install this one which is equipped with the brackets to mount the sway bar to. The kit includes the sway bar, the spring plates for attaching the bar to your leaf springs, and the front crossmember. You will need new bushings (Napa auto parts), and some grade 8 bolts. This one is in nice shape and I will remove the shims that were used for the 6" lift that this came from. NOTE: It may require grinding 1/8" on the u bolt plates if the axle tube is 2.75" diameter.
$90 plus shipping. Shipping will cost between $32-$48. Post office money order or paypal...you cover fees. Thanks, Ray Last edited by KrazyRay; 02-08-2015 at 09:19 PM. |
Re: Another 4X4 Front Sway Bar
PM sent - I'll take.
- Brian FleetFilter.com 1991 Chevrolet V1500 Suburban 4x4 1986 Jeep CJ7 1969 Porsche 911S Targa |
![]() Join Date: Apr 2010
2nd In-line if it dosent work
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer ![]() 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
Sold to POS1 pending payment. Thanks!
2003 silverado, I will have another one soon and let you know. Thanks, Ray |
any luck on a second one??
Its on a truck that I need to take apart. Usually, the sway crossmember is the last thing to be removed. I will try to speed it up.
Thanks, Ray |
Thanks ray just let me know (no rush)
I pulled a 4x4 sway bar today. pics coming soon...pm sent
I still have to remove the crossmember from the frame horns and there are some "chatter marks" possibly from a flex fan launching that will clean up easily with a flapper disc on an angle grinder. Otherwise solid and in good shape.
Please put me in line for sway bar. Thanks.
Posted via Mobile Device |
Ray Pm me your Info for paypal . I will add the paypal cost also Thanks Ray
Sold to 2003 silverado...Thanks!
mesracer...I should have another in about 2 weeks. |
![]() Join Date: Oct 2012
What year trucks are these from? My Blazer has a bar that looks Ike this but I need bushings and not sure what application to ask for?
Thanks. Jeff Posted via Mobile Device |
These are from 73-87 trucks.
#15 |
Thank you. Do you ever come across just the cross member? Is the cross member the same on a truck that was not optioned with a sway bar? Whoever put the one on my truck did not use the cross member, they created some bracket mounts. It works ok just not real pretty and this. May be something I want to clean up.
Thanks again. Jeff Posted via Mobile Device |
#16 |
The crossmember is the toughest part to get because it requires cutting up a frame and they are specific to the sway bar. I have another sway bar setup available. mesracer is first up.
Thanks, Ray |
#17 |
Ray,
Please put me inline for one of these... Thanks..
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
#18 |
#19 |
One more available!
#20 |
![]() Join Date: Jan 2012
i'll take it if you have another one
#21 |
pm sent
#22 |
I have another one available!
#23 |
I would be interested. Can you send me some pictures? Would it have the front cross member like the last ones?
Thank you Evan Posted via Mobile Device |
#24 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#25 |
This one has the cross member just like the other ones. It works with stock height suspension and will require shims between the cross member and the sway bar for lifted trucks. I have seen these shims installed on tuff country lift kits, but they are easy to make on your own. I will post pics of this one soon.
Thanks, Ray |
