Suspension Swap
Hi guys, I was just wondering I have read alot on here about swapping the 4 wheel drive suspension in a 1970 Jimmy/Blazer with two wheel drive. I was wonding if the suspension out of a 73 suburban will swap right over with no problems? the front and rear and the tranny crossmembers?
Addicted user
Re: Suspension Swap
Yes you can, this has been covered a couple times here and many have done it... Use the search and you will see lots of info..
Also check this out: http://www.sporttruck.com/techarticl...wd_conversion/ - As for swapping out with your 73' suspension if it is from a 2wd the front crossmember should fit i believe and try to grab some trailing arms for the rear end or a 4 link set-up.. WElcome to the board!
1972 2wd Blazer - 95% completed 2015 Silverado 1500 4wd -z 2008 AERO 9-7X (TBSS cousin) LS2 1970 Jimmy 4wd - future project |
