Old 03-20-2013, 06:03 PM   #1
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Where is the voltage regulator?
Hey guys,
Been having some electrical problems lately. Headlights dim and get bright, volt meter jumping all over the place, and if it's related my thermostat is stuck on cold no matter what. Everything worked before the new engine. After reading around on here I'm thinking it's my voltage regulator. I have a 3 wire alternator so it's external, the only problem? I don't know where it's at. Does anyone know where the external voltage regulators are so I can replace it?
Thanks.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 03-20-2013, 06:46 PM   #2
pwradder
pwradder's Avatar
Re: Where is the voltage regulator?
is this on the 77 in you're sig? if so the voltage reg is internal, there is a power wire and another plug with two wires together. is this what you mean by three wire?
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 03-20-2013, 08:43 PM   #3
THE "10" SILVERADO
Yes this is for the 77. Yes, there is the larger red power wire and the two wires for the plug. I was under the assumption that everything was externally regulated until the 1 wire alternators.
Michael
Old 03-20-2013, 09:28 PM   #4
71swb4x4
71swb4x4's Avatar
You know what they say about assuming!!
You have an internally regulated alternator.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-20-2013, 09:29 PM   #5
THE "10" SILVERADO
Crapola. I guess that means my relatively new alternator is on its way out the door.
Michael
Old 03-20-2013, 10:00 PM   #6
71swb4x4
71swb4x4's Avatar
It does sound like the regulator. Just to be thorough check the belt too and make sure it isn't slipping.
Any parts place should be able to test the alternator if you take it in.
Old 03-20-2013, 10:02 PM   #7
csb#356
When you replaced the engine did you make sure all of the grounds got replaced right?
csb#356 is offline   Reply With Quote
Old 03-20-2013, 10:17 PM   #8
THE "10" SILVERADO
Used the same cable to the alt bracket. took out an old 12 gauge ground from battery to frame and replaced it with a 10 gauge wire. So all the grounds should be good to go.
Michael
Old 03-21-2013, 12:36 AM   #9
PAWS 72
PAWS 72's Avatar
wouldn't surprise me if the alternator is bad.
PAWS 72 is offline   Reply With Quote
